Leaking ARB
Discussion in 'The Garage' started by ryanstrucking, Feb 5, 2006.
  1. ryanstrucking
    ryanstrucking 1/2 ton status GMOTM Winner
    Feb 2, 2003
    182
    Calgary AB Canada
    Ok. Heres my problem, I had a ARB put in my truck last year (DANA 60 front diff) and the o-rings are leaking now. How hard is it to change them?
    I was searching around and I'm a little worried, I see I might have to remove my bearing on the one side to get at the seal housing. If I do will I have to go through setting up my gears again?
    Thanx for the input in advance
    Ryan
  2. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    No, it might say to, but no, no need to redo the setup of the gears
  3. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Not as long as you put the shims back where they came from.
  4. ryanstrucking
    Feb 2, 2003
    182
    Calgary AB Canada
    Thanx for the input guys.
