leaking beads
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by halftop, Dec 1, 2001.
  1. halftop
    halftop Registered Member
    Nov 1, 2001
    20
    MODESTO, CA
    anyone ever had problems with the beads on your tires leaking air? i'm running bfg mud ta's on 15x10 chrome steel rims. any fix to this problem.
    76 blazer.. like a rock
  2. 78Blazer
    78Blazer 1/2 ton status
    873
    Michigan
    You can put bead sealer on them it usually helps out. Probably have to take them to a tire shop and have them do it for you.
    Scott
    78blazer
  3. ricka
    ricka Registered Member
    Nov 24, 2001
    40
    Beaverton, Oregon
    I had some aftermarket 15x8 modular steel wheels and I would lose my bead quite
    often while I was running 31" Yokohama's. Then I moved to 32" TSL SXs and I
    still was loosing the beads. Then I went with bead locks from Willamette Wheels.
    Zero problems since. I use to drop to about 15-18 psi and I'd lose beads. Now
    I routine go to 11 psi and I'm sure I could go lower. Besides cost, bead locks
    aren't street legal (although I've never been hassled here in Oregon) and you
    can lose bolts every once in a while. If you lose two in a row, you might leak
    around the bead. I carry spares bolts just for this.
    Rick Anderson (rick.d.anderson@tektronix.com)
    Tektronix, Inc. Beaverton, OR 503-627-2630
