LEAKING DIFF FLUID
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Me89'Jimmy, Apr 24, 2003.
  1. Me89'Jimmy
    Me89'Jimmy 1/2 ton status
    Oct 6, 2002
    127
    Sykesville, MD
    i installed new gears in my 89 10 bolt and now im leaking diff fluid out of the where the pinion goes into the diff, is it a messud up crush leaf or what? Help me quick /forums/images/graemlins/confused.gif
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Sounds like the pinion seal got messed up....OR...it is leaking where the spline on the pinion gear meet the splines on the yoke. A little RTV will cure the latter.
    -- Mike
  3. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Yes, it is a crush leaf !
    the leaf crushed the seal instead of the bearing, and now its leaking. Replace the crush leaf, and the seal,
    and do not forget the pinion bearing pre-load, very
    important !
    Good Luck
  4. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    /forums/images/graemlins/rotfl.gif
  5. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Get the right pinion seal.
