leaking driveshaft slip yolk
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 87superblaze, Jan 24, 2002.
  1. 87superblaze
    87superblaze 1/2 ton status
    Mar 12, 2001
    104
    Upper Michigan
    87 blazer with 241 T-case (slip yolk coming out of T-case) New drive shaft from Arizona Driveshafts. Rebuilt T-case and new rear seal. ATF seems to be coming from nowhere???? I switched to the old d-shaft for awhile and no leaks! Switch to the new one and it leaks?? Beats the s^^t out of me! Any comments very welcome.
    BTW 2" spring lift, 2" block W/ 2 deg. angle, T-case lowered, 14 bolt FF. THANKS for ANY help.
    My Truck <a target="_blank" href=http://www.community.webshots.com/user/nicksm79>http://www.community.webshots.com/user/nicksm79</a>
  2. 87superblaze
    Mar 12, 2001
    104
    Upper Michigan
    OOPPS! I see a post right under mine. Posted near the same time. But more comments welcome. What is the fitting they are talking about?
  3. New driveshaft in, it leaks, and old driveshaft in it doesn't. I would take it back to AZ Driveline and ask what's up, might be there problem, might not. But they might have an answer anyway
    Just a thought
    '84 K5
    Chevy in my blood.
  4. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    there should be a plug in the end of the splined yoke, behind the u-joint, this is usually a flat plug that seals the end of the yoke, I've seen them leak before.
    '95 Chevy Silverado 1500
    5.7 V8-NV4500- 3.73 rears
    See My Toys: <a target="_blank" href=http://community.webshots.com/user/wdb172454>http://community.webshots.com/user/wdb172454</a>
