leaking head gasket
Discussion in '1982-Present GM Diesel' started by DieselBurb, Apr 21, 2003.
  1. DieselBurb
    DieselBurb 1/2 ton status
    Oct 8, 2002
    201
    Mt. Vernon, Missouri
    I think I have an internal head gasket leak between cyls 5 & 7 (verified with compression guage). Will it hurt to drive it as long as I have coolant and monitor the oil for coolant in it?
    Diesel /forums/images/graemlins/burb.gif
  2. DieselBurb
    Oct 8, 2002
    201
    Anyone?
  3. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    If you let it go long enough you might burn a groove in the head where the gasket let go, but its unlikely. Id say get it changed as soon as you can, but dont expect everything to be peachy when you take it apart.
  4. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Have you tried to use some of those block seal or radiator seal?
    I have before and most of the times it fixes it.
    I only had one engine so far not work with these things and I am going to take it apart this week end to see why not.
  5. DieselBurb
    Oct 8, 2002
    201
    I used some bars leak a while ago when my radiator was dribbling a bit. Other than that, no. I suppose I could put some block sealer in. Any opinions on it?
  6. DieselBurb
    Oct 8, 2002
    201
    I finally got the head off. Boy, now I understand one reason diesels are so heavy. It was actually leaking from a water jacket into Cyl #7. It wasn't in too bad a condition, just a little pitting. /forums/images/graemlins/thumb.gif I'm gonna clean it up and put it back on and then do the other side for a little insurance.
