Leaking in the bottom of 6.2 inj. pump. Serious?
Discussion in '1982-Present GM Diesel' started by Jaguargt, Apr 28, 2003.
  1. Jaguargt
    Jaguargt Registered Member
    Mar 14, 2003
    46
    Guatemala
    the inject. pump on my 6.2 it's leaking in the bottom but i can't see where, would be a serious problem?, expensive?, can i continue using it with this problem? thanx boys.
  2. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Probably leaking from the throttle shaft, could be from the timing piston too. Pull the pump and inspect it and have the right seals fixed, not too bad a job.
  3. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    Yeah, it's probably leaking from the throttle shaft. That would be causing your hard starting problem. It'll probably keep getting worse until you get it fixed.
    How many miles are on the pump? You might want to replace the pump or have it rebuilt. If it's got low miles, just replacing the throttle shaft seal will suffice.
    Casey
  4. Jaguargt
    Mar 14, 2003
    46
    Guatemala
    Thanx, everyone for response, i don't know how many miles are on the pump, i recently bought my truck, i think i'll use it until i get enough money for a rebuild, how much do you pay for a pump rebuild?, thanx.
  5. arveetek
    Mar 1, 2002
    722
    Here is the best price I've found so far:
    http://www.accuratediesel.com/
    A member over at the Diesel Page just had a pump rebuilt by this company, and he is very happy with the results. They rebuilt his old 6.2L pump to the new 6.5L 4911 specs for $175 plus shipping. When I had my pump rebuilt locally in 1996, it cost me around $350.
    Casey
