leaking jar ..only so many fingers!
Discussion in 'The Garage' started by jakeslim, Apr 26, 2003.
  1. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    Ever notice how you stop one leak, then another starts, stop that one, then another starts, and on and on...
    I fixed leaking...
    intake gasket, then
    i fixed leaking..
    transmission pan, then
    i fixed leaking..
    fuel line, then
    i fixed leaking..
    intake again(did it right this time!)then
    what is leaking now? heater hose to intake, a bit of an oil drip from front of engine..could be oil pan gasket?
    I only have so many fingers to plug these leaks (like the cartoons)
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Sounds about right... /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/deal.gif
  3. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
    I feel your your pain /forums/images/graemlins/crazy.gif
    Some how I have the same problem as you every time i turn around there is another damm leak. Sonner or later the will all be fixed I hope.
  4. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    All my leaks like to happen at the same time. My front main seal is leaking, something on the back of the engine is leaking, my transfer case is leaking, the axle seal on the front passenger side. And whenever I go through deep water, my rear pinion seal likes to start leaking. /forums/images/graemlins/crazy.gif
  5. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    I consider it my K5 taking it apon its self, in its obvious superiority the the heeps and exploders, to mark its territory permanently. /forums/images/graemlins/thumb.gif
    -Ryan /forums/images/graemlins/k5.gif
