Leaking pumpkins
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CAPTAINK5-CT, Jul 31, 2001.
  1. CAPTAINK5-CT
    CAPTAINK5-CT 1/2 ton status
    Sep 10, 2000
    124
    CT, USA
    Both my front and rear diffs have now developed leaks. Any thouhgts?
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I'd guess cover gaskets, or pinion seals.
    Generic Signature
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  3. Ryan B.
    Jul 18, 2001
    5,693
    CA
    crawl under there and determine if it's leaking from the pinion seal or the diff. cover.
    Maybe if you just tighten the bolts up it will go away if your lucky.
    Maybe you'll find you have to change the gaskets, get split lock washers for all the cover bolts, and use locktite on them. That's what I have to do 'cause I find the bolts vibrate loose.
  4. CAPTAINK5-CT
    Sep 10, 2000
    124
    CT, USA
    Thanks for the help. My mech thinks it might be the pinion seals. Oh well, maybe after the summer camping season.
  5. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    Mine was leakin where the yoke shaft goes into the diff. 2.50 part and it was fixed!
    1984 K-5
    4" lift
    35x12.5 MTs
    buildin a 400 for it, any info greatly appreciated
