leaking rear dif
Discussion in 'The Garage' started by Greenk5, May 1, 2007.
  1. Greenk5
    Greenk5 Registered Member
    Apr 16, 2007
    5
    Washington State
    after some light wheelin this weekend i noticed fluid leaking from my rear differential wheere the drive shaft enters it. Anybody know what could be causeing this or have any tips on how to fix this? Im assuming there is some sort of seal inside here. I've never opened one up so i wouldnt know.
  2. WhiteBurb
    WhiteBurb 1/2 ton status
    Mar 10, 2005
    307
    Louisiana
    Pinion seal.. You have to remove the pinion to replace it. It's a pain if not impossible if you don't have the right tools.
  3. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    it aint that bad.
    1. Put truck in air
    2. remove tires,brake drums
    3. pull cover, remove center pin/c-clips(if pin is broken go to step 12)
    4. pull axle shafts out.
    5. unbolt main caps. (REMEBER WHICH IS FOR WHICH SIDE and what is up and down)
    6. remove carrier
    7. remove d-shaft
    8. on the pinion yoke, not how many threads are exposed, then take a chisel or something of the like and score the nut, adn pinion so they can be lined up later.
    9. remove nut, pinion
    10. replace seal.
    11. repeat in reverse order. (be sure to NOT go past your scribed line on the pinion)
    12. walk away pitching afit. thencome bcak witha drill, screw outs and a beer. adn have "fun" lol
  4. ct85k10
    ct85k10 1/2 ton status
    Oct 25, 2005
    121
    Charlotte, NC
    assuming this is on a 10 bolt
    to do it the easy way (not the corect way but the i did it this way and havn't had any problems yet) you don't need to do the steps in red
    to do it the correct way you need to replace the pinion seal which is a pain
    this might help also http://coloradok5.com/forums/search.php?searchid=523367
  5. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    oh yeah. now that i think about it your right...:doah:
