Leaking steering fluid
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by J.C.Staley, May 20, 2002.
  1. J.C.Staley
    J.C.Staley Registered Member
    Sep 23, 2000
    71
    Utah
    I'm going through steering fluid but not real quickly. The leaf springs and shock on the left side is covered with steering fluid. It's not coming from the hoses or the fluid resivoir. It seems to be coming from the steering unit it's self. Maybe a crack? How big of a job is it to change out a steering unit?
  2. rcpilot
    rcpilot 1/2 ton status
    Feb 22, 2002
    507
    Central Cali
    J.C. I have the same problem and it's the input shaft seal.. A input shaft seal kit is only $7.00 at AutoZone and Kragen.. I was told just to remove the dust seal and the shaft seal and replace them.. About 15 minutes of work after you disconnect the steering coupler..
  3. Anteak
    Anteak 1/2 ton status
    Nov 7, 2001
    105
    Hemet, Ca.
    How did you get the lock nut off? Is it a regular right hand thread? I tried the hammer/screwdriver and with a large pair of Channel-Locks, but it only moved @ 1/8". Then tried to turn it the other direction and it goes @ 1/4". Tried some more in both directions without any success. Bolted everthing back together, took the kit back and living with the leak. Any hints to get it off? Do I need to back off the spanner nut first??
  4. J.C.Staley
    Sep 23, 2000
    71
    Utah
    Thanks for the input. I just got off the phone with my brother, he's the parts manager for the GM dealer back home and he told me he could get me a new steering gear from GM for $800 ($500 family discount) or a seal kit for $7. The seal kit is on the way.
