leaking tranny cooler lines
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TxK5Blazer, Mar 13, 2001.
  1. TxK5Blazer
    TxK5Blazer 1/2 ton status
    Aug 13, 2000
    593
    Floresville, Tx
    i have just replaced my stock 305 with a 1995 350 and rebuilt the tranny my cooler lines are routed wrong and leak all the time how can i fix with out going broke all help would be appreciated. Thanks Jason
    K5, Like a piece of heaven, right here on earth
  2. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Either replace the lines with new ones (dealer or the guy who rebuilt your tranny) or get a straight piece from a parts store and bend it yourself. Its a lot cheaper than redoing your tranny! Good luck
    creepin' and crawlin'
    Jim
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Bending your own is good and saves money. Just be sure to secure it to things that don't allow it to flop or it will eventually split and start leaking. The factory uses all those clips for a reason.
    Also, you can generally bend it by hand as long as you don't expect sharp bends. To keep from collapsing the tube while making sharp bends, you can buy a cheap hand tubing bender that will work on a variety of sizes. I don't remember where I got mine but I've had it for years. Works on most anything from break lines to fuel/tranny lines. Some people fill the tube with sand (I don't recommend it) or other things but if you do that, be sure to clean it out *really* good.
    Bad Dog
    85 K30 CUCV, 350 TBI, TH400, NP205, D60/C14, 4.56
    Coming soon: 4" lift, 40" tires, massive cutting, shorter wb and rear overhang.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Most hardware stores carry those tubing benders. A good auto parts store should have them as well. $10-20 is the price range I usually see for them.
