Leaking trans ANYONE HAVE PART NUMBER
Discussion in 'The Garage' started by BozoWise, Aug 4, 2005.
  1. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    Did a search and found some conflicting answers to this. I had a factory installed th350 and 203. I removed the 203 and replaced it with a 205. I now have leaking trans fluid coming from the adapter plate. The adapter plate has a machined lip that I cleaned and made sure that there were no chips between the two.
    Some of the answers I found while searching was that the th350 and 203 combo came with a rear seal in the trans output. I haven't removed to confirm this and I do not see any of the trans fluid making it into the 205 case. But I also haven't driven it since there are no drivelines.
    When I installed the 205 I did not put any sealant or gaskets on the adpater between the trans and adapter. The adapter was already installed on the transfer case and it does not leak.
    Do I need sealant between the adapter and trans? Do I need to replace a seal in the rear of the trans? Is the space inside the adapter suppose to be filled with ATF under normal conditions?
  2. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    There is a gasket that goes between the transmission and the adapter also. Some use an O-ring, but all can use the gasket.
    I would hesitate to use RTV there for fear of it getting in the tranny and plugging up a passage
    Hope this helps.
    John
  3. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    I can't find a part number on autozone.com nor gmpartsdirect. Anyone have it?
  4. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    Anyone have any idea on the part number. My dealer was no help.
  5. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    Shameless bump... Never had a question unanswered on this knowledge filled board?
  6. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Isnt there a groove around the tailshaft and IIRC there should be a large O-ring in there
    No gasket or RTV just the O-Ring..
    Just go to a tranny shop and ask them for the o-ring..I have thr red line where the o-ring goes
  7. rocknutah
    rocknutah Registered Member
    Feb 7, 2005
    61
    slc utah
    Leaking Trans
    Which adapter did you use?
  8. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    Factory 205 to th350 adapter. It does have the grooves like in the picture. It was already installed on the 205 so I just unbolted my 203 from the trans adapter and all and stuck the 205 in. I had to replace the front output shaft seal on the 205 and thought I had ALL my leaks fixed. Now I have a small leak from the th350 tailshaft. It is trans fluid leaking out from the tailshaft and the front of the adapter. I salvaged the rubber gasket off the 203 adapter and will try to install it and see. I would like to get a new one so I can be done with it.
    I'll try the trans shop.
  9. rocknutah
    Feb 7, 2005
    61
    slc utah
    Trans Leak
    Try A Gm Part#1358899
  10. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    Rock I owe ya a beer your the man. That is the correct number I was looking for to take to the stealership.
