leaky 14 bolt
Discussion in 'The Garage' started by Chaddy, May 24, 2005.
  1. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    I put ord disk breaks on and replaced the seals and 1 side leaked and so i replaced that 1 and it still leaks!! WHY?! Could i have a bad hub?
  2. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    how is the seal area on the spindle? and have you put in the seal correctly? i have made the mistake before and it sucks. also check your case vent. it could be pluged.
  3. Chaddy
    May 23, 2005
    4,110
    Salt Lake City,Utah
    i did put it on right and i did clean the spindle, also checked the seal on the spindle and im not sure its leaking out of the actual seal
  4. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    You might need a speedy sleeve to to seal it up. I think I saw an article at Pirate showing how to do it.
  5. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    First make very sure the surface that the seal rides on is not only clean, but smooth. Then make sure your wheel bearings are adjusted properly.
  6. gone huntin
    gone huntin 1/2 ton status Premium Member
    Oct 25, 2004
    1,706
    Coldwater, MS
    Mine leaked from both sides with new seals so I put on speedy sleeves. I can tell you from experience that O'rielly's has them at the best price.
  7. Chaddy
    May 23, 2005
    4,110
    Salt Lake City,Utah
    leaks
    did it work well? hard to put on? my spindles are shiny, they look new.
  8. gone huntin
    Oct 25, 2004
    1,706
    Coldwater, MS
    Well, yeah, it worked great, but mine had grooves in them.
  9. mouse
    Nov 10, 2003
    1,448
    Great Falls Mt
  10. Chaddy
    May 23, 2005
    4,110
    Salt Lake City,Utah
    thanx
    thats awsome now i just have to order..........thank you!
