Leaky axle seal and wobbling rear wheel, interconnected????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by kickinasphalt383, Apr 1, 2002.
  1. kickinasphalt383
    kickinasphalt383 1/2 ton status
    Dec 6, 2001
    224
    Michigan
    My right rear hub seal is leaking and my right rear wheel wobbles/hops at roughly 50mph. is the wobbling wheel causing the seal to leak? and is the wheel just out of balance or is something wrong with the hub that is causing both the wheel to wobble and the seal to leak?
    thanks
  2. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Your axle shaft is probably bent, which wore out the seal. You can get a new axleshaft for about $100 new or cheaper used, and seals are cheap too.
  3. kickinasphalt383
    Dec 6, 2001
    224
    Michigan
    a bent 14-bolt axle shaft!?!?!? no way! i will have to check that
  4. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Is it a SF or FF 14 bolt
  5. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    If your axle is bent it most likely is a SF.
  6. kickinasphalt383
    Dec 6, 2001
    224
    Michigan
    no, its a full float 10.5"
  7. A&P
    A&P Registered Member
    Dec 3, 2001
    88
    San Antonio, Texas
    Although I have a 12Bolt rear, I had this problem about 4 months ago. It turned out to be the outer axle bearing. I rented a slide hammer at the local parts store and swapped the bearing out. In the end I had to replace the shaft due to the fact that the ruined bearing had started grinding away at the axle shaft and it was out of round. So, rented and replaced the bearing, and seal 2x and the axle shaft once. I hope this helps.
    -Ben
  8. Sparky
    Sparky 1/2 ton status
    Aug 20, 2000
    423
    San Antonio(summer) Texas A and M (school year)
    Get your own sig. darnet. Original auther huh? Who was the first one to have it in writing? Who was the first one to have it on here?.... I rest my case.
  9. ChevBlazin
    ChevBlazin 1/2 ton status
    Feb 4, 2002
    332
    St. Paul area, Minnesota
    maybe your wheel is out of balance and your axle seal just happens to be leaking?? I dont think the hub bends easily on those axles, no experience or proof though.
  10. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I have a friend who had the same senario happen to him. The inner wheel bearing on the hub went bad to the point that it wallered out the inside of the hub not allowing the race to stay where it is supposed to and also ruining the spindle on the rear end. Very expensive to fix so he just swapped the whole rear out for another.
