leaky brakes WTF????
Discussion in 'The Garage' started by sapper, Oct 20, 2004.
  1. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    Well the hits just keep on coming. Im about to s can this dodge axle because everything is a PITA. I guess to be difficult they changed things just enough to piss people off. The lastest set back, brake lines, the bango bolts were bigger than the bolts on my ten bolt, the inside diameter of the brake line hole was 7/16th, so i drilled them out thinking it would work, went to bleed them and fluid is coming out everywhere. So is it because i drilled them and need new lines?? Not a big deal because i have to get longer anyway to deal with the 52s just want to see what others have to say. TIA
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You do have two copper washers on each side, correct? One under the head of the bolt and one between the fitting and caliper?
  3. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I have a dodge 60 in my K5. I have aftermarket stainless lines and it bolted up without any problems. I did have to put in new crush washers (twice) however.
  4. sapper
    Jul 11, 2001
    3,052
    NoVa
    Yea i have both washers on the lines and whats funny is on one side i have the ones that came with it, they are about twice as thick as the replacments i put on the other side, but they both leak, mayby i'll try two on the inside and two on the outside and put a little more torque on them /forums/images/graemlins/dunno.gif
