Leaky Holley
Discussion in 'The Garage' started by Confedneck, Sep 26, 2003.
  1. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    so the POS holley carb on my 86 k10 is leaking from the passenger side, i think where it bolts together...but not sure...is it hard to pull a shitty holley apart and put new gaskets in it? i would really rather just junk it and go q-jet...have a couple qjets coming to me on monday...if ones good ill use that instead...but if i have to do gaskets..anyone?
  2. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    The gasket between the body and base plate isn't bad. Clean it good and look at it again, if it's leaking where the throttle shaft stick out then it will bushings - that's when the suck-factor goes way up.
  3. Confedneck
    Nov 1, 2002
    5,236
    on second inspection, it looks like its coming out of where a screw goes into the passenger side of the carb...i think its the other end of the throttle shaft... so i think ill deal with the leak with some rtv...for now
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Gasoline turns RTV into a slimy mess. So that option might not be the best idea. /forums/images/graemlins/frown.gif
  5. Confedneck
    Nov 1, 2002
    5,236
    well then a silicone sealer that resists gas and oil...they have it at the hardware store right up the street...
  6. MEPR
    MEPR 1/2 ton status
    Oct 21, 2002
    1,546
    McChord AFB
    why does everyone hate Holleys? Once i got mine tuned whith my dad it runs better than half the edlebrocks i see. /forums/images/graemlins/confused.gif
  7. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    I love mine. /forums/images/graemlins/thumb.gif
  8. MEPR
    MEPR 1/2 ton status
    Oct 21, 2002
    1,546
    McChord AFB
    about the ont problem i have seen is on steep hillclimbs they flood out. But i came up whith cool cheat to fix that, mount it 90* off centre and no more steep hillclimb problems /forums/images/graemlins/wink.gif
  9. Confedneck
    Nov 1, 2002
    5,236
    well...mine idles really well off camber seeing as how they picked my truck up with the slide bed and were dragging the front tires up the bed and the rear end was still hanging off the back...she kept idle pretty well..but lately ive had all sorts of idle problems with it..and i want a q-jet anyways...
