leaky master cylinder
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by G.M.H, Jan 29, 2003.
  1. G.M.H
    G.M.H Registered Member
    Oct 6, 2002
    78
    wpg. mb canada
    My master cylinder is the older style (1980) that has the lid held on with a wire clip.Any time I tilt the truck a little (often) fluid leaks out the cap.It is wrecking the paint on everything.Is this normal,or is mine faulty? Will a newer style fit,or do they leak also? Thanks.
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Something's wrong with your cap. It shouldn't leak. /forums/images/graemlins/shocked.gif Sounds like it might have a small hole in the rubber gasket. I think you can buy just the gasket. /forums/images/graemlins/cool.gif
  3. G.M.H
    Oct 6, 2002
    78
    wpg. mb canada
    Thanks Harry. I will pick one up tomorrow. The original one leaked, so I replaced the entire unit with a rebuilt one, and it leaked from day one. So I thought it was normal.
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    whats interchangeability of the 81-up aluminum cylinderswith the older iron ones ? will they all bolt to all the boosters ?? i found out that on cars they wont,.. caprices and firebirds and cutlasses and so forth,
