leaky, NP 208, help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BSav, Apr 27, 2003.
  1. BSav
    BSav Registered Member
    Nov 4, 2002
    41
    South East N.H. USA
    I have a stock 88 4x4, 350, TH700R4, I drive mostly high way miles and I've been noticing oil all over the back of the tailgate and the window. Well the T case is dripping slowley and the wind is throwing the drips on the tailgate and rear window. In aout 150 miles it is down about a quart. I'm woried I don't want to burn through this T case.
    Do you guys think the seal is gone? Their semes to be no holes or visible cracks in the case. How hard is it to pull the case and re-seal? What does it get realed with? a premade gasker or form a gasket? Could you guys give me a brief lesson on how to pull the T case,or should send it out and let some one else deal with it? I have a good mechanical knoledge in how to take stuff apart and put back together but just not a ton of time.
    Thanks for the help it is appreated
    Brian Sav /forums/images/graemlins/k5.gif
  2. K5Dan
    K5Dan 1/2 ton status
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    i'd wash it off and try to find where it leaking from first /forums/images/graemlins/thumb.gifcould be just a seal that does not require taking the whole case out if not the case is very easy to get out and they should have a gasket set for it at napa.
  3. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
    Sounds like your slip yoke is leaking.
    If you look at the yoke there is a plug there is where it is leaking. I cleaned mine off real well and put RTV over the plug and had no leaks for about 1 year. When it started to leak agine I went to the driveshaft shop and they sold me a plug pop out the old pop in the new.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Also check the bolts that hold the t-case to the adapter. Those bolts thread into the case on a 208 and if they come loose, then ATF will leak out around the threads. /forums/images/graemlins/eek.gif
  5. yellow81k10
    yellow81k10 Registered Member
    Apr 1, 2003
    15
    Parma Idaho
    /forums/images/graemlins/usaflag.gif i have a turbo 350/208 and just pulled mine to replace seal between transfer case and adapter. easy to pull. on mine the seal is just an o-ring, probally the same with yours. go easy takin the bolts out its just an aluminum case, thats why i had to take mine out. previous owner stripped out bottom two bolt holes and she leaked like crazy. /forums/images/graemlins/truck.gif
