Leaky NP208
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by GloNDark, Sep 23, 2002.
  1. GloNDark
    GloNDark Registered Member
    Sep 4, 2002
    22
    Gardnerville NV
    1985 GMC Jimmy 350/700r4(87)/NP208
    OK why can't I get this #$@&$ transfer case to $%#*ing stop leaking all over the place!
    New front and rear output seals. But it still PUKES out the front output and a drip or two out of the rear. ARGH!! What do I check next?
    The vent is open and clear, the fluid is new, the seals are new, I think it leaks worse with the new seals than it did before....
    thanks!
    Chris
  2. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    if you fill it to the level of the filler plug, does it stay there, or does it seem to get more full? the input seal could be leaking and filling it overfull with fluid from the tranny.
  3. GloNDark
    Sep 4, 2002
    22
    Gardnerville NV
    If I fill it to the full level, and let it leak it just drains out. The tranny is holding it's level just fine. (I thought this was the cause at first.....doh...:()
    My buddy mentioned that if the yokes are too worn that it wouldn't seat up against the seal properly. Where can I get a new yoke at? /forums/images/icons/confused.gif
  4. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    New yokes can be had from most local driveline shops, or get them at the local wrecking yard.
    John
  5. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    Check the plug in the end of the slip yoke(drive shaft end), sometimes they leak out of there also. After having tried to seal mine with silicone I finally got so tired of it that I took it to get welded and on top of the welding I put JB weld, seems like it worked. /forums/images/icons/crazy.gif
