Leaky NP241
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by HuskerBlazer, Jul 2, 2001.
  1. HuskerBlazer
    HuskerBlazer 1/2 ton status
    Mar 22, 2001
    He guys, My '90 has a leaky transfer case. By just looking quickly at it, I'm pretty sure that its from both rear and front outputs. My question may be stupid, but I've never had a TC apart...so how do I put in new seals? Pull the driveshafts and then???
    K-5...Soccer moms inquire within.
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    Nashville Tn
    Pull the driveshafts and use a big screwdriver and pry them out. then tap the new ones in only after you pre-lube them with some grease.
    The rear seal is the easiest. If you have problems with it, you can take the tailshaft hosuing off. Only 4 bolts, then you can get at the seal from the back side and tap it out.
    The front is not that bad, just a little harder to get to.
    HELP! I'm under my truck and I can't reach my beer![​IMG]
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
