Leaky Oil Filter
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1979Jimmy, Jan 23, 2002.
  1. 1979Jimmy
    1979Jimmy 1/2 ton status
    Nov 14, 2001
    696
    Danville Ca
    I noticed today that my I was leaking alot of oil by my oil filter. I seem to be loosing a fair amount. My underbody is covered with a thin layer of oil. I know a little leakage is to be expected but this is too much. I have had this problem in the past but i can never get it resolved. I have already made sure that there is not an old gasket in the oil filter body and it is tight. Any tips or ideas?
    79 Jimmy, 5" lift 35 M/T with a 383 puttin out 400hp and 450lb/ft. 4.11s Locked front and back.
  2. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Try a new oil filter.. I've had some problem's with them in the past.
    Eric
    from Freekmont,CA.
    <a target="_blank" href=http://www.community.webshots.com/user/vwryda>The darker side of nonsense...</a>
  3. 1979Jimmy
    Nov 14, 2001
    696
    Danville Ca
    This is my second one, maybe ill try a different brand
  4. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    New as in different right, and did you NOT overtighten it or forget to put a little oil on the rubber... I know simple stuff, but your sig doesent say master mechanic.[​IMG][​IMG]
    <font color=blue> I'd rather have a bottle in front of me, than a frontal lobotomy!
  5. 1979Jimmy
    Nov 14, 2001
    696
    Danville Ca
    I am far from a master mechanic. I have tried two oil filters same brand but both new both had same problem. I tightened hand light with a lil 40 wieght rubbed on the asket to help seal.
  6. chevyfumes
    Feb 24, 2000
    38,584
    266
    Oh,see theres the problem your rubbing the asget with oil [​IMG]LOL J/K
  7. chevyfumes
    Feb 24, 2000
    38,584
    266
    Oh and by the way I'm closer to a master bater than a master mechanic, but the small stupid stuff gets overlooked first[​IMG]
  8. SWAMPRNR
    SWAMPRNR 1/2 ton status
    Apr 7, 2001
    296
    Temple Texas
    The pressure relief spring stuck on mine once and balloned the filter causing it to leak at the seams.
    <font color=red>A BIG HAMMER CAN FIX ANYTHING.... </font color=red>[​IMG]
  9. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    There's one other thing to consider.......If you have a leak at the rear of your driver's side valve cover gasket, it can drip down the block and look like it's actually coming from the filter area. It might be worth checking.......
    <font color=red>DIGGING AND DIGGING AND DIGGING</font color=red>
  10. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    Make sure the old filter did not leave the gasket on the block. I had a Fram filter do that once and it leaked like hell untill I realized what had happened. I took off the new filter and pulled off the old gasket, no more leak.
  11. sosamantx
    sosamantx 1/2 ton status
    Aug 14, 2000
    393
    somewhere in Texas
    make sure the bolts that hold the oil filter adapter are tight?? might want to take it off and look at it??
    <font color=blue>Steve Sosa a.k.a. "sosaman"</font color=blue>
    <a target="_blank" href=http://sosaman.home.texas.net/carpics.html>http://sosaman.home.texas.net/carpics.html</a>
