Leaky radiator
Discussion in 'The Garage' started by retroblazer, Mar 4, 2006.
  1. retroblazer
    retroblazer 1/2 ton status Premium Member
    Nov 30, 2003
    284
    158
    Gustine
    The is my second one. I had the tanks recrimped once, but the passenger side just started leaking again and I'm leaving tomorrow for Baja. I figure I might be able to use stop leak to get me by, but I'm wondering if anyone had come across a good replacement or custom made one without the bull sh t plastic tanks. This is for my 94 Sub:mad:
  2. azblazer
    azblazer 1/2 ton status Premium Member
    Jul 20, 2003
    695
    15
    Grand Junction, Co.
    I'm thinking a ron francis is the way to go...but your time frame is going to land you at autozone i would assume...
    Good luck down there...my buddy will be down there chasing for a quad team...
    DW
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    If the plastic is cracked, then stop leak doesn't work on it. Been there, tried that. :( I've also got a '94 Sub and the cheapest I found a replacement radiator was around $350. :yikes: Like you, I had new side tanks installed instead, for about $120.
  4. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,232
    490
    New Hampshire
    Well if you are in a pinch, you can crack an egg into the radiator. Believe it or not it works. The heat of the coolant boils the egg and it fills in any wholes there may be. This is only a temp fix!!! You will still need to replace the radiator and flush the cooling system several times.
  5. TDAWG1
    TDAWG1 1/2 ton status Premium Member
    Jan 18, 2005
    2,836
    8
    Grand Junction, Crawlorado
    Ditto on the egg and I found a good price on radiators at Auto Zone!
  6. fasthumpman
    fasthumpman Registered Member
    Oct 22, 2005
    85
    Texas
    ive used black pepper quite a few times with mine and others trucks. seems to do the trick just fine. anyone else done this?
  7. chevyin
    chevyin 1/2 ton status
    Sep 14, 2005
    1,324
    Pismo Bch CA
    You guys are putting eggs and/or black pepper into your cooling systems? Is this a joke or what? rofl
    Besides, seems like peanut butter would work best! :D
  8. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Belive it or not. Eggs and black pepper work good to plug up a leaky radiator in an emergency situation. BUT WARNING!!!!! It smells so good you may want to pull it out and eat it. Radiators are tough and chewey but can provide vital nourishment in a survival situation.
    I have used both methods to plug a leaky radiator when they have had a stick or fan put thru them way out in the bac country. Makes your mouth water all the way back to the nearest greasy spoon for a heaping plate of eggs over easy.
  9. retroblazer
    Nov 30, 2003
    284
    158
    Gustine
    Did you have new plastic or aluminum tanks put on? I used the GM Cadillac pellets. So far, so good. I'm leaving today for a 2400 mile drive to Mexico. But as soon as I get Stateside, i'm putting another one in.
  10. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    I had new plastic tanks put on. I haven't seen replacement aluminum ones. :( Good luck! :cool1:
