leaky tailshaft
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 89k5blazr, Apr 26, 2002.
  1. 89k5blazr
    89k5blazr Registered Member
    Apr 24, 2001
    48
    The Garden State
    I've got driping tranny fluid off the first u-joint comming off the transfer case on the rear driveshaft.... would it be the rear tail seal on the trans? or a seal on the transfer case???
  2. k5blazerus
    k5blazerus 1/2 ton status
    Apr 22, 2001
    654
    Bend, OR
    Most likely a t-case seal. ITs a quick and easy fix.
    Colin
  3. k5blazerus
    Apr 22, 2001
    654
    Bend, OR
    Colin
  4. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Right at the slip yoke? You can get a new seal at your local parts store, the one for my 208 was $1.09. I use a pvc pipe as a seal driver.
    Drain the fluid. Pull the shaft out, take a 3/0 gauge fishing hook and pull the ring seal out. Clean the surface real good.....when you think you have have clean enough, clean it again. Put the seal into the input and gentley drift the seal in with the pvc pipe.
  5. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    if the seal is leaking you will see the fluid dripping at the seal, it will also be sprayed on the floor of the truck above the seal from the spinning driveshaft. if it's dripping at the u-joint the plug in the end of the yoke is leaking(behind the u-joint) this will throw fluid above the u-joint on the truck floor. I've seen many plugs leak like this. remove the driveshaft, remove the front u-joint, pop the plug out from the yoke, clean it well, as well as the groove in the yoke where it seals put it back in with some permatex sealer and put everything back together, probably a good time to replace that u-joint. the fluid travels down inside the yoke through the splines and seeps out of that plug. if you don't fix it right away be sure to fill your transfer case regularly.
