Leaky TH400 help???
Discussion in 'The Garage' started by eldon519, Aug 18, 2002.
  1. eldon519
    eldon519 1/2 ton status
    May 27, 2002
    161
    Kennesaw, Georgia
    My TH400 has been leaking for some time now, and I checked most of the usual spots but couldn't figure out where it was coming from. It turns out it is coming out where the shift linkage meets the case and is dripping off of the Equalizer lever. I did not know this was even possible. Is there an O-ring back there or a seal that I can replace without removing the entire tranny? Also, if I can replace the seal or O-ring, will I have to re-adjust the shift linkage?
  2. YtseJam
    YtseJam 1/2 ton status
    May 19, 2002
    147
    CT USA
    It is called the shift shaft seal and is easily replacable without removing the trans. Pop the linkage out, remove the nut, remove the seal and install the new one. 1/2 hour tops!
