Leaky thermostat housing
Discussion in 'The Garage' started by mudbog42, Sep 9, 2006.
  1. mudbog42
    mudbog42 1/2 ton status
    Jul 16, 2006
    452
    Florida for now
    I have replaced the gasket on the thermostat housing about three or four times, put a new housing and it holds for a few months then begins to leak again. Happened this time when I drove back to Florida from Tennesee. Way up there it was fine. Any Ideas??:eek1: :o
  2. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    I've only had success with the nice thick cast iron thermostat housings. The aluminum/chromed/pot metal stuff is terrible. Other than using a gasket with perhaps some sealant, no problems.
  3. mudbog42
    Jul 16, 2006
    452
    Florida for now
    I have one of the cast iron ones, i think, I got it from Kragen. If its not where could I get one?
  4. ryoken
    Jun 13, 2003
    29,623
    1,379
    Jersey Shore
    make sure your surfaces are flat... I like to drag a flat file over them and mill as nescessary... Use a sealant like Perfect Seal, Permatex #300, etc on both sides of the gasket... Do NOT use silicone...
  5. BoondocK5
    BoondocK5 1 ton status Author
    May 13, 2006
    10,035
    63
    Salt Lake City, Utah
    I always use permatex 2B it never hardens, works great with or without a gasket
  6. ryoken
    Jun 13, 2003
    29,623
    1,379
    Jersey Shore
    Nor do the ones I mentioned... :wink1:
  7. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    you CAN use silicone, you just have to know how to use it ;)
  8. ryoken
    Jun 13, 2003
    29,623
    1,379
    Jersey Shore
    Silicone sucks... Well, standard blue RTV sucks.. I should quantify that... The ultra black and some of the others are ok because they have more elastomeric rubber properties to them..
  9. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    Is the intake pitted real bad or anything? Is it aluminum or cast? I have had pretty good luck with after market housings with a rubber O ring. Dont get the really cheap one like at autozone though go through jegs or summit. They have a couple quality ones. Also sounds like the intake could be warped as well I would try the trick ryoken was talking about as well
  10. mudbog42
    Jul 16, 2006
    452
    Florida for now
    I was also thinking the intake could be warped. Its the original cast iron one that came with the truck so its 20 years old but I'll probably try what ryoken said first though then maybe get an edelbrock performer later when i save some money:D
  11. ryoken
    Jun 13, 2003
    29,623
    1,379
    Jersey Shore
    You'll know real quick if you drag a short file over it... It'll cut those high spots... They like to "pull up" at the bolt holes sometimes...
  12. diesel4me
    Jul 24, 2003
    17,553
    939
    Massachussetts
    leaks suck...
    I've had my share of aggravation with leaky water outlets on Chevy's too....its part of the ritual of owning one..!
    In many cases the water outlet is hairline cracked,and it only leaks during overnight parking as it contracts or while warming up under expansion..this especially applies to the OEM die cast ones..
    The "O" ring style do work better,but hope you wont need a new "O" ring if you have to replace it far from home or a speed shop...not your everyday common easy to find gasket really...
    I used a rubber gasket made from an old inner tube on a 283 I had that defied my every effort to seal it(probably had a warped intake surface) ..it worked pretty good,but only lasted a year or so..never leaked a drop,then one day it started gushing..:eek1:
    I ended up using "Indian Head Gasket Shellac" made by Duro/Permatex,along with TWO usual thermostst gaskets.. --it sealed it for good,but I had to use a hammer and chisel to get the gasket off next time I changed it!..that stuff is like a weld in a bottle!..:doah: :crazy:
