Leaky valve covers fix
Discussion in 'The Garage' started by moneypit, Apr 16, 2005.
  1. moneypit
    moneypit 1/2 ton status
    Sep 3, 2000
    1,382
    COLORADO
    Anyone got one?? Do they make a kit to go from side bolt to center bolt?? Or do I just need to spend some dough on cast ones? I also heard there is a gasket with metal in it to keep from crushing the gasket around the bolt holes....Anyone know who makes them?? I'm sick of the oil mess from these pieces of poo ....
    TIA-Moneypit
  2. raptorparts
    raptorparts Registered Member
    Aug 31, 2004
    16
    gastonia, nc
    cast covers work much better cuase they hold their shape much better. i haven't used the steel shim gaskets yet. good luck!
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    do you have a PCV setup? It really helps with leaky gaskets. Look in Summit, they have those metal inserted gaskets. They have a metal sleeve around the bolt hole so you can't tighten down too far. There is a Center bolt to side bolt switch but not the other way around that I know of. I'd invest in a set of cast aluminum jobbies, thats what I'm going to do on my 383.
  4. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    I know they make kits to go from centerbolt to side bolt, dont see why they wouldnt work the other way. I believe paceparts.com has em. As for the gaskets, mine have the metal in em, but I cant remember who made em, lemme go see if I can find the box.
  5. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    I was having the same problem and went to aluminum valve covers with rubber gaskets and have not had any more poblems. Do you have a small block? If so they make hold down tabs for them I have a set that are chrome if you want them they are yours?
  6. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
  7. thor
    thor 1/2 ton status
    Aug 20, 2003
    512
    Wa
    How deformed are your mounting surfaces. Problem with 99% of tin covers is that they are bent from overtightening. If they are not flat the embossed gaskets won't help.
  8. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    The only valve covers that didn't leak on my old 355 were the cast aluminum covers. I used the neoprene gaskets and torqued the bolts to about 10-12 lbs.
    Rene
  9. moneypit
    Sep 3, 2000
    1,382
    COLORADO
    Already have the tabs... Guess its time for some cast ones and some new gaskets...
