Least possible lift with 42's?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigk, Jan 25, 2002.
  1. bigk
    bigk 1/2 ton status
    Jun 13, 2001
    358
    Mendon Illinois
    Least possible lift with 42\'s?
    What's the least you can get away with and still move around in the fenders? Any pics would be great.
    Karl
    Temporarily Unemployed Underwear Model
    87 3/4 ton
  2. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    Re: Least possible lift with 42\'s?
    I know pcorssmit is running a 3" lift and BadDog is running a 4", im going w/a 6 and 39.5s and i think that is a little too much. i guess it depends on how much you want to "trim" from the fenders.
    Dan
    Sun Desert Offroad <a target="_blank" href=http://4x4.alloffroad.com>4x4.alloffroad.com</a>
    83 Chevy, 350, sm465, lincoln locked14ff, (soon to be- spooled dana 60, flatbed,and 39.5" TSL's)
  3. lax037
    lax037 Registered Member
    May 29, 2001
    49
    Long Island
    I'm running a 4" with 42's, took alot out of the fenders though, and when flexing I hit the rear wheel tub. Removed the inner fender on the front to. My body was shot when I did this, Don't think i'm gonna cut as much when I swap to my new body. Hope this helps
    Tom
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    You can make anything work, I'm going for 4" and 42s. Fenders? What fenders? I'm not yet done with mine but I ditched the front fenders and tossed the bed right off the bat. I've still got to cut out the sides of the core support, smooth the pinch welds on the fire wall, and move the axle forward a bit. After that, I'll have to see if the tire still hits the fire wall too much at full stuff (I expect it will). If so, the fire wall will be modified or moved back.
    Russ
    85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked, 4" lift, 42" tires
    Some day: massive cutting, shorter wb and rear overhang.
  5. mnstr_fx
    mnstr_fx Registered Member
    Sep 13, 2001
    78
    IL
    My old 1 ton had 4" and 42's. MAJOR front trimming is needed to not rub and if you flex alot, you will still rub on the cab at full flex when turning your wheels. It would be best to also move the front axle forward 1" to avoid rubbing on the cab. My new truck has 6", with the front axle moved 1" forward. NO RUBS! Though I still trimmed the heck out of the front fenders.
    76-82 Chevy Pickup / Blazer - K5-K10-K30
    90' TBI
    TH 400
    203 / 205 Doubler
    Dana 60, Corp 14 - 4.88'd - Detroit Locked
  6. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Actually, I'm looking at 1.5, maybe even 2" forward on the front axle. Tires clear the firewall, better approach angle, etc. I'll just need the shaft re-tubed. Moving the axle forward will also help drive line angles AND keeps the pinion pointed correctly for the CV even after the lift.
    I'll start with a smoothed firewall and 4" of lift just to see exactly how far I have to go. Trimming is not an issue for me. Unless I change my mind, I'll be running a bobbed front like Scott at RockStomper (and the other guy with the flat bed K30 that was at Moab) with no fenders and a hood cut way down for better visibility. If I run fenders at all, they will be cut away like Marv's Green K5 and the MoneyPit. After having a chance to look at things, the axle will likely be offset to the front but I don't know how much the firewall needs to be modified. My goal is NO rub regardless of turn or stuff. If that means moving the body back, then I will move the body back. I'll probably move the core support back a bit too so that I can cut the front frame off more (better approach again). Lots of ideas, I'll have to see how it works at stage 1 before I can be sure exactly what I'm going to do.
    Anyway, thanks for the info.
    Russ
