Leaving your hubs locked
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazin72, Dec 13, 2000.
  1. blazin72
    blazin72 1/2 ton status
    Oct 24, 2000
    279
    Oklahoma
    Hey guys
    I was wondering if it hurts to leave your hubs locked in and your transfer case ingaged over night. Alot of snow on the ground and I just pulled in and shut it off, will this hurt.
    Sorry if this sounds stupid I am new at this.
    Blazin72
  2. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    No. It won't hurt a thing.
  3. blazin72
    Oct 24, 2000
    279
    Oklahoma
    I didnt think it would but I thought I better ask.
    Sure enough that I didnt it would have been the wrong thing to do.
    BLAZIN72
  4. nyyef
    nyyef 1/2 ton status
    May 16, 2000
    479
    Saudi Arabia
    thats the beauty of having everything mechanical
    Knife.
    knife.coloradok5.com
  5. mudfanatic
    mudfanatic 1/2 ton status
    Feb 18, 2000
    614
    Aloha, Oregon
    When I was growing up we left our hubs locked in from late October to mid February (unless we would be planning a trip on the highway) just for saftey purposes, if we hit a patch of snow my dad would pull the rig into 4HI and there was never a need to get out. We also hunted and from time to time we would be out hunting and run across a spot where we needed 4wheel, with a pull of the lever we were locked in. The reason my dad never wanted a full time though was that we had lots of friends who had the F**d auto systems and the hubs would get cold and not lock all the way in therefore screwing up the ends of the axlestubs or breaking the auto hub itself.
    Dan
    <font color=red>get involved with land issues or lose the land</font color=red>
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    There's quite a difference between a full-time 4WD system and a part time system that uses auto-hubs. There aren't any hubs that engage or disengage on a full time system. The wheel is always attached to the axle so everything is always spinning. On Dana 44's and GM 10-bolts there's a solid splined hunk of metal that makes the connection between the wheel hub and the drive axle. (I carry the originals from my 3/4-ton 44 as spares to use in case a locking hub breaks).
    The solid axle full time 4x4's got a reputation for poor fuel mileage and the tendency to "crow hop" when making tight turns in parking lots and the like. A standard u-joint does not like to operate beyond about 7 degrees of motion. Plus having just 1 u-joint in each axle shaft means that there isn't another properly phased u-joint to offset the motion a u-joint creates as the shaft rotates. This made the vehicles tend to jump with each half rotation of the front wheels when turning tightly. With todays CV jointed, IFS 4WD's, full time 4WD rigs don't do the hop any more. Mileage isn't that big of a deal either, since most 4WD's these days come with front axle disconnects instead of locking hubs. This means that in 2WD most of the front end is still spinning anyway.
    I usually leave my hubs engaged most of the winter. This gives you 4WD "on the fly" similar to the new part time 4WD rigs. Just yank the lever and keep going. Note that if you have a locker or limited slip up front, you'll probably want to unlock the hubs when possible. With the locker, steering will be affected with the hubs engaged, even in 2WD. With a limited slip, you'll be putting a lot of undue wear on the clutches.
    http://ThunderTruck.ColoradoK5.com
  7. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    during the winter i have my hubs locked and the t-case (np205) in 2-hi. but then again i am lazy and dont want to get out of the warm cab lol
    s.smith 77blazer lookin 4 mud
  8. Hobbes68
    Hobbes68 Registered Member
    Mar 20, 2000
    80
    Yonkers, NY
    I leave my hubs locked when there's snow on the ground or in the forecast too. So much easier than getting out when you're already stuck! There's no need to unlock them, but it does place an extra load on the front drive line. Not to mention the added wear and tear that everything moving all the time might cause. Not enough to worry about though...
  9. BIGRIG
    BIGRIG 1/2 ton status
    Feb 29, 2000
    488
    Independence, MO
    What are you guys talking about...OK so Im REAL lazy mine are locked in 340? days a year! Never know when you might be driving down the road and one of those pesky trails will pull you over and you dont have time to lock in. :) If they wear out buy new ones!
    MY DRINKING TEAM HAS A FOUR WHEELING PROBLEM!
