LED front blinker problem HELP!
Discussion in 'The Garage' started by xtrmjoe, Feb 1, 2005.
  1. xtrmjoe
    xtrmjoe 1/2 ton status
    Aug 3, 2004
    330
    Boonville, CA
    I bought LED square lights I wanted to use for the front blinkers. Problem is there is 3 wires on the old one and only 2 on the new LED light. One original wire is ground, one is 5 volts when the lights are on and one is for the blinker 0v then 12v.
    How in the heck can I wire this up?
  2. xtrmjoe
    Aug 3, 2004
    330
    Boonville, CA
    I know ord did it with ther new front bumper maybe I should ask them.
  3. xtrmjoe
    Aug 3, 2004
    330
    Boonville, CA
    guess i will just put 2 on each side one for blinker and one for marker.
  4. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    what happens if you hook the ground to ground and both other wires to the hot side of the light, 5 volts should be a dim burn, and the 12v pulse should give full light.
  5. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    Who did you buy them from? Didn't they come with instructions? For some reason I think I recall that you need to buy an adapter or circuit board to make them work correctly. I'll see if I can find the post that mentioned that...
  6. sweetk30
    Nov 1, 2004
    25,536
    533
    horseheads , ny 14845
    1-2 light on reg system o.k. but if all led lights , need led flasher unit for them to flash . the draw is so small that reg flasher wont work.
