LED wiring help
Discussion in 'The Garage' started by Impex, Mar 18, 2004.
  1. Impex
    Impex 1/2 ton status
    469
    Chandler, AZ
    got my new LED's intalled
    but im having trouble getting the brake and turn to work since they are the same wire is seems, i dunno am i doing something wrong... /forums/images/graemlins/dunno.gif
  2. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Brake and turn use the same wire... The LED's should have 3 wires, ground, stop/turn, and tail.
  3. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Yep just like my trailer light specials on the flatbed, except mine ground through the mount. If they dont work that way something up front is messed up.
    Nice setup there BTW /forums/images/graemlins/thumb.gif
  4. Impex
    469
    Chandler, AZ
    well, if my brakes are on the turn signals won't work,(just stays solid) but if the brakes are off then they work fine, also if my tails lights are on (work fine) but once i turn on the blinker the both flash like hazards.
  5. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    So does your truck use the same wire for turn signals and brakes stock? Or did it have seperate wires? If it had seperate wires you have to buy the turn signal adapter thing made for trailers. You can buy them at most auto parts stores in the trailer light section.
  6. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Seems he has a '78 so it should be like mine.... hmmmm... mine or his might not be stock wiring though...
