left front end popping
Discussion in 'The Garage' started by PURPLE1, Nov 28, 2006.
  1. PURPLE1
    PURPLE1 Newbie
    Nov 28, 2006
    va
    I have a 1989 Blazer w/ 4in susp lift and 33 12-50's. When I go over a pot-hole, rock, etc. it makes a loud clunk or pop that I can feel in the steering wheel. I have had both upper and lower ball jts replaced. IT makes the noise if hubs are locked or unlocked. Any help would be EXTREMELY APPRECIATED!!!!!
  2. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    see if your steering box is firmly attached to the frame
  3. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Did it make the noise before the ball joints were replaced?
    Check:
    Drag link
    Steering box
    Shock bolts
    TRE
    Spring bolts
    Sway bar bolts
  4. PURPLE1
    PURPLE1 Newbie
    Nov 28, 2006
    va
    Yea, it made the popping before and the local 4x4 mechanic thought it was the ball jts because they did have some play in the drivers side.
  5. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Well, you just have to get under there and see what's loose.
    Might help to take the weight off the suspension (jack up by the frame), it's easier to grab and wiggle stuff that way.
    I had a noise like that once on my '97 K2500, turned out to be the shock bolt was coming loose.
  6. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Could also be loose body mounts
  7. SLOK5
    SLOK5 1/2 ton status
    Apr 25, 2005
    216
    SAN LUIS OBISPO CA
    I have the exact same setup and I can make mine pop by just turning the wheel back and forth.......steering box is tight with braces installed ...... cant find the source of the noise yet....I also have a thing where if im offroading and come back to street driving my wheel is off center to the right. Funny thing is when I bump it against the curb I hear a pop/snap and wheel is fine again.....go figure. I think Ill find it when it breaks. Let us know if you find anything.
  8. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Mine makes that noise and it is the lower leaf in the spring pack slipping one way then the other when I turn the wheel. I might have a loose or broken center pin I just have not had the time to take it apart and see.:o
    Ira
