Left front tire skidding
Discussion in 'The Garage' started by dendeanda, Jul 1, 2005.
  1. dendeanda
    dendeanda Registered Member
    Apr 21, 2005
    46
    Corpus Christi, TX
    85 K5 Blazer 350 Auto
    Someone side swiped me and caused my right steering knuckle to break which left my tierod hanging. It was a pretty hard hit but I think the knuckle took all the force. The tierod and ends look fine. The knucke, brake pads, and ball joints were replaced. The brakes could have been bled a little better though.
    On the test drive, theres a little pull to the right but nothing too bad. But at about 30mph, I started to notice that, if I veer ever so slightly to the left, tap on the brakes, or hit a bump, the left front tire starts to screech against the road. What could be causing this?
    -Misalignment?
    -Bent tierod?
    -caliper sticking?
    Thanks guys!
  2. 1-ton
    Apr 17, 2004
    2,884
    165
    Las Vegas, Nevada
    Sounds like your right side tire may be toed out. It probably needs an alignment.
  3. dendeanda
    Apr 21, 2005
    46
    Corpus Christi, TX
    Well, It turns out the that alignment was REEEEALLY bad. I was told that the next time I needed an alignment that I was going to need a new outside tierod because there are no more threads available! Thanks for the help all!
    Dennis
  4. LongIslander26
    LongIslander26 1/2 ton status
    Jun 25, 2005
    256
    Park County, Montana
    Tie rod ends
    If that's the case, then something is still bent and should probably be looked at.
  5. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    get it so it drives right then pay close attention to your tire wear and that sould tell you if it is at least tracking straight, my guess would be bent a whole lot more than you want to fix..... frame, spring hangers, springs, axle tube....these are all just guesses but if it drives straight run it, if something else is FUBAR it will destroy itself in time
