lefthand D60 spring plate needed
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 4X4HIGH, Aug 23, 2002.
  1. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    exactly as stated, I need a lefthand/driverside spring plate for a D60.
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> You might try giving Boyce a call, they may have them. </font color>
  3. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    dealer has them too--can't remember part # off hand but if you need it ill look for it
  4. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    if u dont wanna pay dealer prices, try gmpartsdirect.com. They cost ~$43 shipped there... my dealer wanted $61.50. Of course, the dealer can get u one in 24 hours... and gmpartsdireect is slow. the part # is 370055 for the driver's side one. I ordered a 370056 today from gmpd... I need a passanger side plate. /forums/images/icons/wink.gif
    J
  5. madmike
    madmike 1/2 ton status
    Jan 23, 2002
    496
    ohio
    Believe it or not, I just removed my 1/2ton 10 bolt front axle, and replaced it with a Dana 60. I had already ordered the D60 spring plates from the dealer, in preparation for the axle swap. I got to looking at that new spring plate, and it was the same as the 10-bolt piece. $61.50 not very well spent!
  6. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Thanks for the info. I will check into it. Someone used a D44 or 10 bolt passenger side plate on the driver side of the D60 I picked up and the bolt spacing is obviously wrong because of the pumpkin portion but maybe the driver side plate is correct.
