Length from centerline on axle tube to u-joint on 14B and 10B
Discussion in 'The Garage' started by Fubeca, Apr 21, 2003.
  1. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    Does anyone know or have the ability to measure the length from the center of the axle tube to the face of the pinion yoke on a 10bolt and on a 14 bolt(FF)? I have done a search but am having a hard time finding this info /forums/images/graemlins/frown.gif. The driveshaft guy is telling me I need to shorten my driveshaft and I don't have the 10 bolt anymore to see what the difference is.
  2. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    Not sure about the 10 bolt... If I remember correctly, its the same as the 12 bolt. When I swapped, I dont think I did anything to my driveshaft. Anyways, here is a comparison shot of a 14FF and a 12 bolt with a tape.
    14FF
    12B
    Mike
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    When I went from 10 bolt to 14 bolt I did nothing to my driveshaft. (700R4/208/10bolt) The pinion of the 14bff is closer to the tcase output, but not by a huge amount. My stock driveshaft worked fine. (2.5" lift) I did notice some more vibs in the driveline. Partially due to the pinion angle being a litte more off due to the closer snout, and partly because the 14bff gave me a little more lift. (.5" or so)
  4. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I measured up my 12B & 14BFF recently from axle centerline to u-joint centerline to get a guestimate on any driveshaft issues that I might have after the swap. Using a couple of straight edges, a tape measure and my calibrated eye( /forums/images/graemlins/rotfl.gif) I came up with about 13/16 difference, the 14BFF being longer of course. /forums/images/graemlins/thumb.gif
  5. Fubeca
    Dec 18, 2002
    2,100
    Denver Area
    Thanks guys
