Length of oil dipstick and tube
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mofugly13, Oct 24, 2002.
  1. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    The PO of the 73 K5 I just got a few weeks told me it had a rebuilt 327 in it but the numbers on the block ID it as a 350.nyway, it has a busted off oil dipstick tube. So I picked up a chrome SPECTRE replacement at Kragen. The package says its for Chevy small blocks but it doesn't match the existing one. The old one has a longer dipstick AND a longer tube. Yhe new stick is about 4" shorter wand the tube about 2" shorter. What is the length of the correct dipstick and tube?
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I don't think it matters how long the combo is, as long as the part from the hole to the end of the stick is the same.
  3. mofugly13
    Oct 6, 2002
    2,813
    San Francisco
    They're not the same. With the original one in, it reads full. When I put the other one in, I barely get any oil on the tip of the stick. I guess what I really need to know is how much dipstick needs to actually go into the pan.
    Matt
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    So put more oil in it... /forums/images/graemlins/thumb.gif
  5. mofugly13
    Oct 6, 2002
    2,813
    San Francisco
    Uhhh, gee, OK. How 'bout I use the shorter tube and the longer dipstick, then I'll NEVER be low on oil. /forums/images/graemlins/rolleyes.gif
    Seroiusly, I've got to make a LOT of little repairs like this (guages don't work, 203 only works in HiLoc, no fan, radiator held in w/ tie wire, etc...) before I can really start building it for off roading, and I like to do things RIGHT the first time around. /forums/images/graemlins/thumb.gif
  6. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    I would change the oil and put the specified number of quarts in it ( make sure its a stock oil pan and check for an oil cooler). Then run it, check it, and calculate from there which dipstick to use. If they don't look right take your block number to your chevy dealer and get help at the parts counter.
