length?
Discussion in 'The Garage' started by berserker, Jun 14, 2006.
  1. berserker
    berserker 1/2 ton status
    Nov 19, 2005
    127
    columbus,ohio
    anybody know how long would i have to extend my driveshafts for an eight inch lift? or what else i would have to do? besides cross over steering and brake lines.
    85 k5 39.5/15/15r TSLs
  2. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    shocks and degree shims for your pinion angles
  3. berserker
    Nov 19, 2005
    127
    columbus,ohio
    what about driveshafts
  4. BoondocK5
    BoondocK5 1 ton status Author
    May 13, 2006
    10,035
    63
    Salt Lake City, Utah
    If'n your interested I've got a complete set of skyjacker 8 inch springs with bushings, front and rear springs, 400 bones plus shipping
  5. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    ive currently got 8" springs on my k5. the front shaft will actually work stock (im not doing anything to the front shaft until i get my doubler) and the rear one i had lengthened about 4" i think. the rear angle is still bad, but i havent broken any ujoints yet. im not doing anything else with the rear either until i get my doubler finished then i will order new cv shafts. my set up is 350/700r4/208 currently. depending on ur tranny/t-case urs might be different
  6. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    To do the drive shafts correctly you'll have to do the lift then measure. There is no way to tell before you do it. Different drivetrains and different vehicles all have different results. I have had stock driveshafts from vehicles with the same drivetrains not fit. After the springs are in and it is sitting at ride height measure from the center of the U-joint to the other center of joint.
  7. berserker
    Nov 19, 2005
    127
    columbus,ohio
    wanting to get sm465/205 52" 4" lift springs 4" shackle flip 4" lift rear
