Lenthening my own drive shaft..
Discussion in 'The Garage' started by Zeus33rd, Jul 10, 2003.
  1. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    After adding some new springs and larger tires, my old beat-to-death stock drive shaft was starting to show some splines. Since I'd rather do something myself and make it the way I want, than pay someone else to do it- I decided to lengthen it myself. /forums/images/graemlins/thumb.gif
    Here's a few pictures of the progress so far-
    This is the splined end of the shaft. After cutting the old tube off, I machined a shoulder into it to be pressed and welded into the new tube..
    This is the yoke end of the shaft. I couldn't figure out a way to get it chucked up in the lathe to machine it perfect- This is the facory machined surface after cutting the old tube off..
    Old stock driveshaft tube on the right, @ .069 wall, new drive shaft tube on the left @.250 wall.. /forums/images/graemlins/eek.gif I'm going to machine the I.D. of the new tube to match the O.D of the yoke and splined ends of the shaft for a tight press fit, then weld it up.
    As for balancing, if it's needed, the old shaft had no balance weights, I think I can accomplish that with a hose clamp around the shaft, some weights and trial and error. If all else fails, I'll send it out to be balanced. But I think it would be pretty damn cool to make it all work myself. /forums/images/graemlins/pimp1.gif
  2. madmike
    madmike 1/2 ton status
    Jan 23, 2002
    496
    ohio
    Kewl, looks like a winner!
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Nice, you have access to some cool toys. I'm sure you can make it work with a start like that. I've built several shafts that work fine (several fronts, and a few rears) and I don't do anything but cut the tube off, then tap the ends into new tube. On some of the fronts, just cut, sleeve and weld. I wish I could do work like that! /forums/images/graemlins/thumb.gif
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Looks good, show some more pics after is gets finished /forums/images/graemlins/thumb.gif
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Don't forget to install a driveshaft safety hoop. If the front u-joint breaks, and that 1/4-inch wall tube digs into the road, it'll pole vault ya into orbit! /forums/images/graemlins/eek.gif /forums/images/graemlins/wink.gif
  6. mastercraftkpk
    mastercraftkpk 1/2 ton status
    Mar 12, 2003
    192
    Houston, TX
    I second the hoop idea. That is a super cheap mod that yuo may never need...but if you do...you are a GENIOUS.
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  7. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I did one a couple of years ago...
    I tacked every thing together...
    bolted it-up to the truck...
    indicated it...to make sure it was close...
    pulled it back off the truck...and completed my welds...
    Looks Good!!! /forums/images/graemlins/cool.gif
  8. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Good idea. /forums/images/graemlins/pimp1.gif
  9. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> He'd have to have one hell of a high angle CV in the front in order to let the diff end of the shaft hit the ground! /forums/images/graemlins/eek.gif </font>
  10. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Hmm, If the u-joint at the t-case breaks, the shafts falls to the ground- What does a high angle CV have to do with it? /forums/images/graemlins/thinking.gif /forums/images/graemlins/1zhelp.gif
  11. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I think he thought you were doing a front shaft.
  12. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Ohhh.....That would make sense. /forums/images/graemlins/pimp1.gif
  13. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I was thinking front shaft... I need a front shaft, so I must have been projecting. /forums/images/graemlins/tongue.gif </font>
