Less then favorable compression test results on 97 tahoe
Discussion in 'The Garage' started by COCHEV, Sep 12, 2004.
  1. COCHEV
    COCHEV 1/2 ton status
    Jul 9, 2002
    4,055
    Washougal WA
    Tune up day. decided to do cap, rotor, plugs and wires. so i thought i'd check the ol' compression while i was at it. didn't like what i found. test was dry, no oil added.
    oh, specs: 104K on vortec 350
    #1- 150
    #3- 140
    #5- 150+
    #7- 95 /forums/images/graemlins/confused.gif
    #2- 150
    #4- 140+
    #6- 145
    #8- 140
    don't know why #7 is so low. should i worry about it? i can feel it running a little rough and thats why i decided to to the comp. test. how long do you think before that cyl. takes a total dump. could be a valve i guess, i'd have to do a leak down.
  2. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    With that drastic of a difference I'm thinkin you're prolly right on the thoughts of a valve or seal or somethin along those lines.
  3. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    possible its a ring on #7, when my tree fiddy was in its death throes I had a couple cyl's really low, the rings were non existant in those cylinders.
  4. COCHEV
    Jul 9, 2002
    4,055
    Washougal WA
    So do i really want to pull the heads off my wifes daily driver to see whats up? /forums/images/graemlins/thinking.gif
    might as well get a lt4 hot cam to put in while i'm at it. /forums/images/graemlins/waytogo.gif
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If you do pull the head I'd put a piston in that hole.
