Let me change the wording to my question>>>>>
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Burt4x4, Jun 23, 2000.
  1. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    What type of spark plug wires do you run in your K5?
    Any pros and cons to the set you have?
    The last set I bought I had bad luck with, so I'm just trying to get a real world testamony on a set of wires.
    Thanks for the help
    Rock ON![​IMG] 72 K5 [​IMG] Led Zeppelin
    http://burt4x4.coloradok5.com
  2. CK5
    May 19, 1999
    21,623
    701
    CO
    I have a set of Taylor's with the ends set at a 45 degree angle and like them, I have about 30,000 miles on them with no problems.
    Steve
  3. Scoobydoo
    Scoobydoo 1/2 ton status
    Jun 9, 2000
    244
    Phoenix / Peoria ARIZONA. (75thAve/DeerValley)
    What brand did you have bad luck with?
    I don't like "accel" myself[​IMG]
  4. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I've got the Autozone brand. Their great, for what I paid for them.
    YEEEEE HAWWWWW[​IMG]
  5. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    I'm currently running a set of Taylor customs. I like making the lengths myself since you never end up with a wire thats 5 ft longer than it should be.
    http://www.off-road.com/chevy/rodent/engine/engine2.jpg
    If I was in the market for some, I'd check out the thicker wires like MSD and Accel has. The thicker the wire, the less likely you will ever have a misfire. Also check out Magnecore wires http://www.magnecor.com/index.htm which I've heard nothing but good about from the other performance groups.
    Shawn
    87 K5
  6. 4x4blazer
    4x4blazer 1/2 ton status
    Jun 14, 2000
    278
    Louisiana
    I have used Splifire Dual Mags for about 2 yrs now and haven'thad any probs with them. I dont run spltfire plugs though. I guess the only con I can think of is that the wires are a little stiffer than most, so on some of the "pop-in" style wire seperaters some of them tend not to stay popped in too good if they have a sharp bend in them somewhere.Did that even make sense? heh,oh well I hope this helps a little!
  7. CK5
    May 19, 1999
    21,623
    701
    CO
    Shawn, I think you better get out the Windex, I thought I saw a spot on the valve covers. [​IMG]
    Steve
  8. Shawn
    1,753
    5
    5280'
    Thanks Steve.... I'll get on that of ASAP!
    At least I wash my engine!
    Shawn
  9. BigBadBowTie
    BigBadBowTie 1/2 ton status
    Apr 6, 2000
    160
    AZ
    <font color=purple>I'm useing Summit Racing Igniton Wires. They come in Custom Fit or Univeral Fit. I did like Shawn did, didn't want those excess wires, so I bought the universal, which is a few $$ cheaper too. I also had Accell's before this, what can I say I changed to the Summit's. I have been running these Summit's for about 3-4 years now, no complaints.</font color=purple>
    http://store.summitracing.com/product.asp?ssid=N2B6Y6N3VONFISHT3R1H4T5DSU&orderid=343NCN3SF8LTJLDYO7NPC8M7FQYKC8UOCM5S&p=A6ED276D-3612-11D3-949D-080009FC5B5F
    <font color=purple>Rick
    86 K-5</font color=purple>
    http://www.BigBadBowTie.ColoradoK5.com
  10. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue> I put on a Moroso blue dist. cap and Blue Max wires when i put the new motor in. I have had no problems with them.</font color=blue>
  11. James90
    James90 1/2 ton status
    May 18, 2000
    986
    Rocky Mount NC
    Shawn that is a sweet looking power plant what is it 350,383,400,or454?
    [​IMG]Go prepared
    </font color=red>90 k5 soon to be big, bad, and mean
  12. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    I run the MSD 8.5 mm super conductors, have not had any problems with them yet. Look good and fit good, no complaints.
    Depdog
    <font color=blue>"Lead, Follow, or BECOME the Trail"</font color=blue>
  13. Shawn
    1,753
    5
    5280'
    Thanks James! It's a 454 which happens to be the 4th engine (can you tell I have bad luck with engines). I was trying to show Burt how I route my wires.
    I was looking closer at those Magnecores and they have 10mm wires which are designed for racing. The only thing is they might cost a little more.
    Shawn
    87 K5
  14. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    I also have the MSD 8.5mm superconductors (the red ones). These wires are supposed to have one of the lowest resistances (low ohms) of all wires. I ordered the 25ft. bulk cable and two packs that had 9 boots and connectors each. I cut them on my own to a nice fit, and saved the extra $20 that a pre-cut and assembled set would cost.
    I had bad experience with Accel Super Stock, but mostly because one of the cables was too short. It was so streched that it came off from the distributor side connector. Not completely disconnected, but very poor contact, causing the connector inside the boot to change color.
    <font color=blue>//////
    http://blazer79.coloradok5.com
    </font color=blue>[​IMG]
