Let me see your shock carnage
Discussion in 'The Garage' started by 78Suburban, Jun 27, 2006.
  1. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    Some people showed concern that if I ran shocks that are 18" collapsed and 30" extended in my STOCK rear shock mounts with an echobit flip, that I would chance cracking my frame around the shock mounts and doing all kinds of damage. Has anyone had this happen? I wanna see some carnage pics :p:
  2. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    my truck had a hairline crack in the frame at the passenger side rear shock mount. Took the truck to my welder and he patched it up real nice.
  3. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    Whats the stock length of shocks?
    Also, cracks at the frame point are always possible if the mount isnt always tight. I check mine every so often, but i know a few that they come loose and move all around in the hole causing cracks.
  4. draggbody
    draggbody 1/2 ton status
    Jul 13, 2005
    282
    columbus GA
    the one on my passenger side bent up and cracked, to remedy this i would weld the bolt in first so that you dont START having problems w/ it... i remedied mine by cutting the frame in front of the leaf spring hanger and removed the body and built a truggy... :)
  5. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    I'm afraid I don't quite have your skills :wink1: I'm still deciding if I'm gonig to be brave enough to attempt to just inboard them :crazy:
  6. blackblazer717
    blackblazer717 1/2 ton status
    Jul 1, 2004
    470
    massachusetts
    heres what happened to mine......
    its the pass, side upper
    and it was cracked lengthways with the frame
    LUKE
  7. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    what shock were you running? What suspension setup? What is the length of the shock compressed and extended? What were you doing when it broke?
    thanks for the pic,
    James
