lets hear your cheap mods that help offroad
Discussion in 'The Garage' started by 85mudblazin, Mar 17, 2005.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Money is tight so I was trying to come up with some things you can do cheap to help offroad.
    Might help some people on a tight budget, so lets here your cheap mods :D
  2. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    Throw away your anti sway bar!
  3. Tuff84blaze
    Tuff84blaze 1/2 ton status
    May 12, 2000
    119
    Liberty Lake, Washington
    --Disconnect swaybar
    --remove bolt from leaf spring clamp in the back
    Thats about all the free stuff I can think of right now.
  4. muddysub
    Jun 23, 2001
    10,454
    493
    my garage, Henderson, NV
    sway bar, spring clamps and fender trimming... about it... welding the differentials if u want to/have the ability.
  5. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    These can be cheap to not just free :D
  6. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    Pull a $20.00 electric fan out of a salvage yard and get 20 HP.
  7. 1985K20
    1985K20 1/2 ton status
    Jan 11, 2005
    191
    Quebec,Canada
    yeah, you can weld that rear end but dont weld it with an arc welder...:whistle:
  8. 1985K20
    Jan 11, 2005
    191
    Quebec,Canada
    got out of crazy situations by decreasing air pressure in tires:waytogo:
  9. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Do a search for "Cheap mods". There are lots of posts
  10. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    52"/56" springs in the front and shackle flip in the rear is a REALLY cheap mod. Had i not used my BLING BLING front shackles in the front, i would have only been in the swap the price of bolts
  11. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    The only problem with that is you usually need x-over steering afer you do that and really long travel shocks, and then you need new shock towers....etc
  12. white-rhyno
    Jan 27, 2002
    942
    true, i guess i never thought into that.
  13. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,862
    296
    Truckee, CA
    If you can find a deal on front springs, a homemade shackle flip can be a great cheap mod (if you have the fab skills to do it right).
  14. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    swaybar, welding or lockrights, decent nused mud tires, lower air pressure, hilift, shovel, ax, electric fans, and shaving as much weight as possible.
  15. stizkidz
    stizkidz 1/2 ton status
    Nov 11, 2004
    219
    near Atlantic City, NJ
    Please explain the spring clamp bolt mod.
  16. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    There are bolts that hold these clamps so that your springs cant fanout, removing those bolts lets them fan out which will increase your droop.
  17. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Any dis advantages of this? This is the first I have heard of such mod. Could be useful for my application:)
    Cheap mod.......If you have a manual tranny hooking a bicycle brake line to your throttle line helps out a lot. Frees up your feet when you have to clutch and brake.
  18. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    the only thing that you should do to prevent your main leaf from bending with the added droop, is to make a clamp that will clamp the 1st and 2nd spring, yes it will limit droop a little but its better than a belt main leaf and will still help with droop.
  19. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    One of My favorits is to take a 3" piece of 3/8(if I remember correctly) fuel line and hoseclamp it to the floatbowl veturi tube on a Q-jet carb. Helps out with the carb bogging and flooding it's self.
  20. stizkidz
    Nov 11, 2004
    219
    Huh?
