Let's play find the oil leak
Discussion in 'The Garage' started by Wingnutt, Apr 18, 2004.
  1. Wingnutt
    Wingnutt 1/2 ton status
    Feb 20, 2000
    324
    NOVA
    Let\'s play find the oil leak
    Granted it's just a tiny one, but leaking engines is one of my pet peaves. There is oil leaking down onto the starter. I ran my finger along the valve cover and it came away dry. I can't see anything when I look above the starter. Anybody have any ideas before I pull the starter off to check further?
  2. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    Re: Let\'s play find the oil leak
    what engine are you running? /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  3. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/grind.gif
  4. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Oh! Oh! I wanna play /forums/images/graemlins/tongue.gif
  5. unclematty
    Jan 24, 2003
    3,164
    SLC UT
    sorry hit the wrong button, probably a mouse motor, so the leak is more than likley coming from the rear intake seal, behind the distributor /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/grind.gif /forums/images/graemlins/grind.gif
  6. Wingnutt
    Feb 20, 2000
    324
    NOVA
    Running a stock '88 350
  7. unclematty
    Jan 24, 2003
    3,164
    SLC UT
    I'll bet if you put your hand down behind the distributor, and feel around there is oil all over the place back there where no one ever looks /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
  8. boggerless
    May 26, 2003
    22,728
    96
    cuz mine leaked from the spot where you could put a dip stick( a 99 crate engine).it sprayed on the header above the starter. /forums/images/graemlins/frown.gif /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  9. unclematty
    Jan 24, 2003
    3,164
    SLC UT
    when you find out, lets hear about it. I'm curious now besides I can probably give some advise on how to repair . /forums/images/graemlins/grin.gif
  10. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    it could be the dipstick, but most likely is the rear intake seal, GMs always leak.
  11. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    There are a couple places back there. My first guess would be rear intake seal. If that is it when you replace the intake do not use the crappy rubber gaskets with the kit. Just lay a thick bead of black sealer along the front and rear and seal it on that way. Trust me on this. It could also be your oil pressure sending unit. Check and see if the case is leaking or see if it's leaking around the threads. Also you or someone else may have had the distributer out and forgot to replace the little paper gasket that seals it.
