Let's play "guess the gear ratio"
Discussion in 'The Garage' started by mountainexplorer, Dec 11, 2004.
  1. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    From the factory, what would you most likely think the axle gear ratio would be in a:
    1986 Chevy 1-ton 4x4 Crew Cab SRW with a 6.2 Diesel, TH400 and NP205.
    My guess would be 4.10.
    4.56 would be too low for a Diesel. But did they put 3.73's in them also?
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I'll guess 4.10:1
    Or more likely 3.73:1
  3. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
  5. mountainexplorer
    Nov 14, 2001
    4,903
    Thats what the guy who own it thinks too. I had an '83 factory 6.2 1-ton that had 4.10s, but wasn't sure if they had many 3.73 60 fronts in the diesels as well. Makes sense though. He says the truck gets 19mpg too.
  6. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    I havent checked my diesel's gear ratio's yet--I'm guessing it has 3.73's,because it seems higher geared than my 74 K20 with 4.10's and the same size tires--the diesel trucks probably are more likely to have a higher ratio(like 3.42 or 3.73 vs 4.10 or 4.56's)due to the lower rpm torque of the diesel--but any ratio can probably be special ordered I suppose.....Someday I'll pull the cover and change the lube,and "de-code" it..
  7. blazd88
    blazd88 1/2 ton status
    Mar 16, 2004
    1,055
    Lubbock, Tx
    iv got one for you!
    1979 1 ton dana60/14ff. it has a 292 straight six,sm465,205tc
    it was a telephone line companys truck so it has a utility bed with a large hydrolic arm in the bed.
    WHATS THE RATIO?
  8. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    4.56
  9. mountainexplorer
    Nov 14, 2001
    4,903
    I'd also guess 4.56 as the ratio from the factory on that 6 cylinder 1-ton.
  10. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    Hmm---phone company truck huh?? ---I've seen some 80's vintage 1/2 ton 2wd phone CO.trucks with 2.56 rear axle gears and a wimpy 5 speed like a chevy monza used in the 70's--so in a one ton 4x4 its a wild guess,but I'm going to say its probably a higher ratio more than a low one,maybe 4.10's or even 3.73's if they had them available in a one ton--seems the phone companies around here thought high axle ratio's would give better fuel mileage--I bet they were wrong!!..
    Or maybe someone with a brain had the truck equipped with a nice low gear like 5.13's or even 6.17's--I've seen electric company bucket trucks with 4wd and dana axles set up for off road use--my friends brother drives a similar rig with an auger for installing telephone poles,his had a 366 with a 5 speed,but it was a 60 series truck,with REAL low gears--topped out at 55mph when the govenor kicked in......
  11. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    Between myself and a few buddies we have purchased several K-20 and K-30 trucks with 292's in them and so far all of them have been 4.56 geared trucks .
    the trucks were as follows:
    1978 K-20 292 465/205 Dana 44 / 14FF open 4.56's
    1978 K-30 Cab Chassis 292 465/205 Dana 60/14FF open 4.56's
    1979 K-30 Crew Cab 292 TH400/203 Dana 60/14FF open 4.56's
    As for the original topic my vote is 4.10's !
    The early N/A 6.2's were not real hot performers and needed a little help in the gear department and as for my expirience 4.10 is very common in the 1 Ton applications - that being said it could have been ordered with 3.73 / 4.10 or 4.56's .
    Tom
  12. westtexask5
    westtexask5 Registered Member
    Sep 25, 2004
    56
    lubbock,texas
    is there any way that it could be a real low ratio like 2.56 or so?
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Nope, D60s don't go that high. That's why the D61 exists, and GM never used it AFAIK.
  14. mountainexplorer
    Nov 14, 2001
    4,903
    Got another one for everyone:
    1979 Chevy K10 1/2 ton 4x4, 292 6-Cylinder, 4spd/205, 12 bolt rear, 10 bolt front.
  15. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    Hmm..3.73
  16. mtn. burb
    mtn. burb 1/2 ton status
    May 13, 2004
    1,260
    Ojai Calif.
    4.56:1
    All the military K30's had'em.
  17. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    For the original question, my guess is for 3.42's or 3.73.
    For that, I say 3.73's. Was there ever a factory 4.10 12b?
  18. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    As for the 1979 half ton truck I would guess a 4.10 gear .
    Tom
  19. mountainexplorer
    Nov 14, 2001
    4,903
    I was given a '76 rolling frame once that looked like it had a 4spd and 203 combo originally... wasn't sure on the motor, but it was a 1/2 ton and had 4.10 gears in a 12 bolt and Dana 44.
    The '79 I got was a factory 6-cylinder 1/2 ton 4x4 truck. When I got it, someone had already swapped a 14 bolt under the rear, but the front was still a 6-lug 10-bolt. I still havent actually pulled covers, but I was assuming 4.10s on that one.
  20. Tuff84blaze
    Tuff84blaze 1/2 ton status
    May 12, 2000
    119
    Liberty Lake, Washington
    MountainExplorer I have a question for you thats kind of related to this topic, where would you recomend somebody from the Spokane area go to have a set of front and rear gears installed on a 10 bolt front 14 sf rear, and about how much should I expect to pay?
    Thanks.
