lets play name my bad TBI sensor
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by gtkustoms, Jan 15, 2003.
  1. gtkustoms
    gtkustoms 1/2 ton status
    Oct 6, 2001
    281
    nm
    Upon start up engine idles normal
    you go to move the truck and hit the gas pedal and the truck starts coughing and missing...likes its only firing on a few cylinders.
    when the truck warms up it goes away no more coughing or missing.
    name my sensor
  2. evilandangry
    evilandangry 1/2 ton status
    Dec 29, 2002
    105
    Norwood, NJ
    Is the check engine light on?
  3. Chris87K5
    Chris87K5 1/2 ton status
    Sep 21, 2002
    322
    Pennsyltucky
    sounds like a coolant temp sensor. Mine did that 'till I replaced it.
  4. Marshall
    Marshall 1/2 ton status
    Apr 8, 2002
    204
    LiveRmore,CA
    wires, plugs, cap and rotor ok? If your not sure its worth a check.
  5. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Could be a couple - TPS (throttle position sensor), maybe CTS (coolant temp). Could also be ignition wires/cap cracked or a number of things.
    Invest when you can in a scanner of some type - www.autoxray.com has a good one that is about $150 that can read not only code problems but drivability issues can be diagnosed pretty easily. Example - in this case you'd know if the TPS was set right by the volts present at idle and on up............ /forums/images/graemlins/tongue.gif
  6. gtkustoms
    Oct 6, 2001
    281
    nm
    new plugs, rotor, cap, coil, wires, etc...
    ran like a rapped ape when I replaced all of the worn out stuff.
    there are no trouble codes going off.
