Lets play, name that wire
Discussion in 'The Garage' started by sled_dog, Apr 8, 2005.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    As you can see its near my collector. The one with the blue wire is my O2 plug, the other one... I have no clue. I never noticed it till after the motor swap now I have no clue where it goes. I kept forgetting to take a picture of it. The plug on my trans is hooked up, same for trasnfer case, its barely long enough to even touch the trans.
  2. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    Did you follow up in to the engine compartment?
  3. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    the one w/ the red arrow is the one for a th400 kickdown switch.
  4. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    ..... my rig doesn't have a TH400, never has, never will. It rolled out of the factory with an SM465. Think it just came with the wiring to be a universal setup?
  5. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    well the shape of it looks like a th400 connector, look in the end of it, if it has 2 spade recepticles in it, in the vague shape of a T, that is a th400 connector. It is possible I guess, perhaps the wiring harness was changed somewhere in the past for burnt wires or something?
  6. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    Nope, it was a one owner vehicle, no engine fires or anything. I'll go look but I think the plug is just a single round hole in the center.
  7. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    if its just a single round hole in the middle then I dont know, if its almost a T (the 2 not intersecting) its a th400. The wire through the grunge looks orange which is the color my th400 wire is
  8. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    well its neither one. It has a single slot connection. It travels down the firewall in the same split loom as the O2 sensor. Best guess I have is the grounding switch for the Clutch pedal(so it knows the clutch is down). I have no idea where that is but I know it works(can't start without the clutch down).
  9. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    I'm not sure which one your talking about the blue arrow or red arrow?
    the blue one looks a lot like my cts plug or distributor plug. the red arrow if i had to guess maybe a second knock sensor. :confused:
  10. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I'm certain you are wrong on both counts. Read the post, I said the blue one is the O2 sensor. The other is a mystery but there aren't 2 knock sensors and they use a different connector style. Thanks for trying, step back and try your luck again :D
  11. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    ah... it was the wire part that got me hung up..,
    What motor is this for?
    Hmmmmmmmmm... oops i ment to say cps instead of cts. but where does the thick red wire go to? If you trace that all the way back you might get a better idea. maybe even follow it back to the fuse box.
  12. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Since you have a 465, theres a switch for the back up lights, then another wire goes to somehting else but im not sure what it does, that what it looks liek to me. Look for another terminal on the top of yoru 465.
  13. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the wire for the reverse lights is a 2 wire plug, the same exact plug for the tcase light.
    the clutch pedal switch is on the pedal assembly so it can't be that.
    it kinda looks like the plug for the electric oil pressure sender.
  14. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    that what i thought but i doubt he missed that.
  15. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    nope that is hooked up. So are both temp sensors, knock sensor, map sensor stuff, everything that I can hook up is.... but not this one. It is a very similar connector to the oil pressure sender one though.
  16. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    it might be the TCS plug for on top of the 465, forward and reverse range would retard spark timing
    or it is for the oil pressure sender
    one or the other im sure, both would be single spade slot like that
  17. BIG STEVE
    BIG STEVE Registered Member
    Jul 23, 2002
    66
    thornton colorado
    The clutch switch is inside on the linkage not that had the sm465 out
    of my 90 last summer almost seems like there were 2 wires on tran top
    back up and? soon as it warms up ill go look if have not found out by then.
  18. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    2 connections on your tranny or 2 wires? There is presently one connector plugged in up there with 2 wires. Maybe I missed a connection up there.
  19. dyeager535
    26,982
    191
    Originally carbed?
    Whether TBI or carbed with electric choke, the early ones will have two oil presure connectors. One for pressure gauge and one for oil pressure for either the fuel pump in TBI, or to kill power to electric choke if carbed.
  20. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    TBI motor. 89, original TBI originally 4 speed too.
