Lets play, name that wire!
Discussion in 'The Garage' started by sled_dog, Dec 6, 2003.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Ok so whats this wire do? Seems to go to the front prop. valve. I want to get rid of the whole wiring harness that goes to the front of the K5 since I no longer need it but this wire is part of that setup.
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    brake warning light? If ya lose brake pressure
  3. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    I believe that is the wire that activates the brake warning light in the dash when you have brake problems.
  4. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Yep,that the warning light,The piston in the proportioning valve has to be centered or the light will come on.....
  5. dyeager535
    26,980
    Yep, it's the brake warning switch that comes off of the combination valve. Ground it, with the key on, and the brake light should come on.
  6. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    didn't even know there was a break light, well since the dash will likely be going as well I don't feel bad getting rid of that.
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I didn't feel bad about loosing it either. /forums/images/graemlins/smile.gif I forgot about it.
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    brake warning, the wire goes to the prop valve on very front x-member, im going to be unplugging mine soon because brakes work fine but the warning light is always on cept sometiems it goes out after pdeal return, but rarely
    maybe someone knows why ? truck sat literally untouched for minimum 4.5 years until recently when i rescued it and made it a daily driver
  9. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    oh i see ,just correct my spelling. mm hmph. /forums/images/graemlins/grin.gif /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  10. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Ok, the final answer is, BRAKE WARNING LIGHT. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
  11. thefarside
    thefarside 1/2 ton status
    Jun 27, 2003
    343
    Vernon, CT
    If you are like the guy that owned my truck before I did you would,
    A. CUT the wire to find out what it is
    Ahhh, the things you find under the dash./forums/images/graemlins/angryfire.gif
