lets play name this part!
Discussion in 'The Garage' started by colbystephens, Jan 5, 2007.
  1. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    i might be adding more parts as time goes by, as i'm trying to learn wiring. :)
    my truck is a 1983 blazer w/ 6.2 diesel, silverado package. cruise/blinkers on column, wipers/lights on dash.
    what is the bright yellow box behind the guages that has a wire set coming out of it that is red, black and green? these wires are all connected along their lengths to one another such that it essentially makes one cable, but its a flat cable - don't know how else to describe it and the camera is at home and i'm not. :)
    any ideas???
  2. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    I name it Bob.
    Only knowing CUCV diesels, I'm thinking it's a glow plug controller, cuz it sounds new to me.
    Is it factory, though, or aftermarket? Related to the radio maybe, or tow package?
    -- A
  3. mr.smartass
    mr.smartass 1 ton status Premium Member
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    Yeah, it's not that radio static deadener sound thingy is it? But i think that's down next to the radio... That's my guess... let's get a poll going.:D
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Been a couple years since I was that far into my dash . Could it be for the cruise control , coming off the speedo thingy , or is your truck not a cruise equipped truck ?
  5. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    it's cruise equipped, but i don't think it's cruise, tho cruise doesn't work and this does have a plug on the end. hmmm??.
    glow plugs... probably not, unless this is part of the deal which makes the glow plugs glow when the key is in the on position... since i've had it, it's never been auto glow, only manual.
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Well prior to the newer trucks with VSS in the transfercase , or rearend . VSS was in the speedometer head .
    I want to say thats what that could be .
    Mine didn't work either , only piece I didn't take off was the turn signal stalk . If by some miracle I fix the body panles , I will use the switch housing for a different type with work .
  7. dyeager535
    26,979
    It's VSS. Color and number of wires, plus description of box give it away.
    On a diesel/cruise truck I suspect the VSS wire(s) went straight to the cruise module above the gas pedal.
  8. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Sounds like VSS to me. Mine is green though. But it has 3 wires bonded together. Small 3x5ish type box, about 1" thick
  9. dyeager535
    26,979
    http://dyeager535.topcities.com/TPI/index.html
    First page, middle two photos. If you look close, you can see the three wires from the other end. I believe that yellow was early, light green later. But it doesn't really matter. Only difference in these is the color and connectors in some cases.
  10. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    ok, i'm convinced it has something to do with cruise, as i found out that it plugs into the back of my speedometer. :)
  11. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Yep, VSS.
