Let's play WTF is wrong with my K5?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by UseYourBlinker, Jul 30, 2002.
  1. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Let\'s play WTF is wrong with my K5?
    Where to start? My 84 has a major vibe. I thought it was a tranny issue. I pull the tranny pan (700r4) and find nothing in the the pan. The fluid was really red,and didn't smell burnt. I also pulled the inspection cover and find nothing wrong with the flywheel/torque converter.The t-case (208) was rebuilt about 3 months ago. All the Ujoints are perfect. The only thing that I haven't checked out yet was the rear axle (gonna pull the cover tomorrow)
    Here's what is happening. The only time I get a vibe is when under load. No vibe when the K5 is stopped (park or neutral),but as soon as I hit the gas it shakes like a fat chick joggin with no bra on. WTF could it be? /forums/images/icons/confused.gif
  2. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Re: Let\'s play WTF is wrong with my K5?
    Sounds like a u joint is about to go out on you. /forums/images/icons/laugh.gif
  3. UseYourBlinker
    Jun 7, 2000
    11,117
    LOL! It's not a U-joint /forums/images/icons/shocked.gif /forums/images/icons/mad.gif
  4. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Have you played with your rear end geometry lately?
    How long has it been vibing you for, any mods recent to that?
    Did you check your U-Bolts?
  5. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Sounds like maybe the pinion is aimed a bit too high in the rear. Since under load the pinion wants to rotate up, it exaggerates a poor pinion angle and can cause a vibe. If it's OK at coast I'd go maybe 2-4 degrees down and see what happens. Lowering the t-case might help it too, but I'd prefer to adjust the angle at the axle.</font color>
  6. UseYourBlinker
    Jun 7, 2000
    11,117
    BorregoK5.
    1st Q.No
    2nd Q.Before the vibe I had my tires balanced,but they would still shake if I had my foot of the gas. right?
    3rd Q.No
    Shaggy, My t-case is allready lowered. I have the stock springs with 2 inch tapered block's,and add-a-leaves.Angle is fine.
  7. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Not to insult your intelligence Eric, But when ya checked your u-joints did you release the parking brake? I always release the parking brake and put it in nuetral when doin u-joint inspections. Grab the shaft, wiggle and look at the u-jont closely...ANY movement in ANY direction means it's time to change it. Another thing to take a look at is the t-case/tranny mount. Stick a socket on the bolts and see if they are loose. Take a gander at the motor mounts too. Wheel bearings of course...Hmmm.....Along time ago I had an '85 K30 that spun the little rubber ring outta the harmonic balancer...Vibrated for awhile before it finally puked it out. Since you said the motor runs rough while it's vibrating and smooths then stops vibrating...Maybe you should check things like fuel pump/filter. Distributor cap/rotor. Take a look around and check for vacumn leaks. Take a gander at the vacumn line that goes to the tranny. Another thing you could do is take a ride down to a tranny shop in your area and ask one of thier guys what they think it might be. /forums/images/icons/grin.gif
  8. UseYourBlinker
    Jun 7, 2000
    11,117
    I pulled the rear shaft out..and took it over to Scott's (4X4HIGH) shop. The joints are perfect. I'm gonna drive the K5 over to a shop tomorrow (Hope I make it)
  9. UseYourBlinker
    Jun 7, 2000
    11,117
    All the mounts are ok also.
  10. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    Take your rear shaft off and drive in 4 wheel drive to see if it still vibes. Then take off the front shaft and go in 2wd just in case. Are your hubs locked by accident? It sounds like driveling angle or u-joint to me.
    Mike
  11. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Before you do that, check the rear yoke coming out of the diff. Look at the pad where the u joint circlip sits. I have had a bad vibe for awhile and what happened was the circlip wore a groove into the yoke and allowed the shaft to wobble. It's not really detectable until the driveshaft is under a good load. It will be obvious on the yoke tho. I wish I had my digi camera, I'd take a pic for you. You can remove and replace the yoke without alot of hassle. Just push it back on and snug it down really well.
  12. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    i second what <font color="orange"> thumper </font color> said. also check the fan blades, make sure they are all there. you'd be surprized how much the play into this vibe stuff. if you can have your tires rebalanced, just to make sure.
    ARQ.
  13. Grim-Reaper
    7,385
    Atlanta
    You sure it isn't an engine mis? I had a vibe that became very noticable after I put the poly body mounts in. cruising it was not noticable, idling not very noticable. Under load like taking off from a light...noticable. I have bad valve guid seals, not to the point it smokes while driving but a little puff at start up. I had a lot of deposits on a couple of the plugs. New plugs and the vibe was gone.
  14. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    lol, I wonder how many posts have been started or have a part dedicated to finding/diagnosing vibrations....I bet the # is frickin outrageous! lol! /forums/images/icons/grin.gif /forums/images/icons/grin.gif /forums/images/icons/laugh.gif /forums/images/icons/cool.gif
  15. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    I had a set of tires balanced and they drove great for a couple of days then I got the wierdest of vibes, the tire shop had nicked the valve stem and the tire aired down just enough for me to notice a vibration under load not cruising, and I didn't notice any strange handling because it felt like body roll.
    How heavy a vibe are we talking about? The amount and kind of vibes could help diagnose the problem. Is it speed dependent, or engine dependent?
  16. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Eric's truck is an 84 with a 700R4 and 208 transfer case which means slip yoke into transfer case and cannot drive with rear shaft out.
  17. UseYourBlinker
    Jun 7, 2000
    11,117
    Thanks for the input guy's. I still didn't get around to pulling the rear cover off yet. I will try the 4wd tomorrow,and see if I get a vibe. I have dealt with U-joint vibes before,and it is not a U-joint kinda vibe. It's an extreme vibration. It's really bad I'm scared to drive even around the block. Any local's wanna come drive my K5 to guess what it is??? /forums/images/icons/confused.gif
