Lets see pics of FORD hi pinion dana 60s installed
Discussion in 'The Garage' started by hi pinion, Sep 4, 2005.
  1. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    Whell lets see :D
  2. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Here's one.
  3. hi pinion
    Sep 25, 2003
    5,354
    What about the passengers side drop dana 60? :D
  4. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
  5. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    you want passenger side drop? you got passenger side drop. :D
    p.s. SELLOUT!
  6. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,005
    839
    Pinckney, MI
    pwned
  7. hi pinion
    Sep 25, 2003
    5,354
    PAWNED? :haha:
    Lets see up in there now, i did a search, but ,,baaaa
    I dont see a writeup on this , sure would be nice. :waytogo:
  8. kgblazerfive
    kgblazerfive keymaster Premium Member GMOTM Winner
    Dec 2, 2004
    10,609
    602
    Hooper, Utah 84315
    Does a 44 count :D
  9. hi pinion
    Sep 25, 2003
    5,354
    Cool :D I dont see a reason anymore having to pay almost 5k for a custom high pinion anymore, after being here and reading about all the other stuff that will be just as strong etc etc,,, so what gives? I know this is yesterdays news, the furd 60 topics and what -not, but, lets see it again? It seems the furds are cheaper as whell. Im just curious as to what degree the ford axles are helping with pinion angle. How much over the standard dana 60 low pinion design?
  10. kgblazerfive
    Dec 2, 2004
    10,609
    602
    Hooper, Utah 84315
    I guess if you can live with having Ford parts on your truck its ok I just call axels Dana :D , and my T-case is a New Process :D . I know where a 78 or so extended cab Ford with two 60's, might be a 70 rear and 205 and it runs, for about $1500 so cheap is soo true. I got mine for $300, the whole truck, then parted the rest and make $450 so I got paid for my rears.
  11. hi pinion
    Sep 25, 2003
    5,354
    This is all fine and dandy, but has anyone OFFICIALLY*** done the swap? And made it work? This could again be old news, after the year and a half of being in the lounge , i need to get my arse back in the garadge and face the music :D
  12. kgblazerfive
    Dec 2, 2004
    10,609
    602
    Hooper, Utah 84315
    Other then size, the swap that I did can't be any different then a 60, it just bolted in and my only problem is my exhaust and that has more to do with my headers.
  13. hi pinion
    Sep 25, 2003
    5,354
    :confused: Hold on , hold on,,,So let me get this straight, they just bolt right in, and thats it? No moving perchs, ? No worries about steering? Just a bolt in High Pinion? No clearance issues? So why not install the High Pinion furd axle from the get-go over the standard pinion setup???????? :confused:
  14. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    You have to find a 78-79 axle out of a Ford for it to be a straight bolt in deal. The spring perch width is the same for 78-79 Ford and 73-87(91) GM.
    Shock mounts are probably gonna need to be moved, but easy to deal with. brakes you just need to know what fitting is on the caliper. Ford used a bigger dual piston caliper than GM. So that is an upgrade, just doensn't work with 15" rims (GM you can just grind till they fit).
  15. hi pinion
    Sep 25, 2003
    5,354
    I would just think this would be something everyone would want, over the reg low pinion 60,,,with the pinion clearance and all, im suprised ,,,lower cost, etc. :confused:
  16. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    Every Ford HP60 I've seen has been going for more money than a comparable GM or Dodge LP60. Of course there are always exceptions, but this is something I've noticed with the online axle sales arena. From what I've seen, the GM 60 occupies the middle of the price spectrum and the Dodge units go for the cheapest (esp. the external hub versions).
    The reason you don't see more of them?
    Could be a few things. As noted above, the 78-79 Ford HP60 axle that bolts into GM trucks is fairly rare. Also, on this topic, the GM D60 is very abundant in comparison, and I'd say even Dodge D60's are more common.
    Another thing that was mentioned above is brand loyalty. Personally I think this is one of the most ridiculous topics ever. But some guys would rather have their wife and kids put to death than slap something from a Ford truck onto their Chevy. Personally, I am swapping a Dodge D60 underneath my truck...I've already had a few die-hard GM types roll their eyes and shoot me angry glares for even suggesting this. In reality, these axles were all made by Dana Spicer, and sold under contract to the truck manufacturers.
    Basically, while yes HP would be nice, in most cases it isn't necessary. And LP 60's are far more abundant.
    And while some people on the internet will make it sound like LP60's are the devil axles and not spiffy enough, its simply not true. Thousands of GM and Dodge 60's get the piss beat out of them daily.
    This is just my viewpoint.
  17. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    there is nothing wrong with a LP, I just happened to get a deal on a couple HPs at one time so thats what I have now. I paid more for my HP then I did for my LP, but thats just $50 more.
    Also, HPs have big dual piston calipers that make them almost impossible to run with 15" rims, so that is a drawback for many(H1 or H2 rims for me, have both), and the knuckles are weaker than the Chevy knuckles. Don't really know why, they are just thinner I guess. Hear of people busting a knuckle on a Ford unit more than you do with a Chevy LP.
  18. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    The knuckles are reportedly weaker on a Ford HP60. That can of course be solved a few different ways so no biggy there either but something to consider.
    As far as brand loyalty I prefer Chevy's but mine is such a hodgepodge of what I consider to be the best parts to acheive my goal, it just doesn't matter.
    I have Chevy, Dodge, Ford and Cadillac on mine. Cadillac is still in the family however the engines are different enough.
    I think the reason most don't search for a HP is they are so rare. 2 years of Ford trucks carry the bolt in axle and the rest are difficult at best to use for John Q.
    Price on any of them seems to vary from seller to seller and buyer to buyer.
  19. kgblazerfive
    Dec 2, 2004
    10,609
    602
    Hooper, Utah 84315
    But you can't just bolt one into a chevy 4x4 you really should change the t-case also :D
  20. kennyw
    Jun 9, 2002
    13,223
    94
    That lower cost is also offset by the cost of a new tcase to switch sides on a GM, not to mention adaptation issues if you want to run a Ford NP205.
