Let's see some drivetrain breakage!
Discussion in 'The Garage' started by BowtieRed, Mar 20, 2003.
  1. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    Let\'s see some drivetrain breakage!
    My worst drivetrain breakage to date. Still not sure how it happened.
    14FF Pinion- [​IMG]
    Let's see yours, then we'll have a vote on the worst. /forums/images/graemlins/grin.gif
  2. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    Re: Let\'s see some drivetrain breakage!
    daaaaaamn
  3. captain chaos
    captain chaos 1/2 ton status
    Mar 29, 2002
    413
    dickinson, north dakota
    OUCH
    maybe it's becouse of the 10/40, insted of the 80/90 it should have had /forums/images/graemlins/grin.gif /forums/images/graemlins/smile.gif
  4. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    I never thought a 14FF broke!!!! /forums/images/graemlins/thumb.gif
  5. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    nah, i THINK i bought it that way. he told me it was loaded with oil, so i was driving in front wheel drive, no rear shaft, and drove at 15mph, 1/4 mile, and then pulled the cover a few days later. there was NO oil. not sure if I did that or if it was like that when i bought it.
  6. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    What does the ring gear look like...
    Chris
  7. DieselBurb
    DieselBurb 1/2 ton status
    Oct 8, 2002
    201
    Mt. Vernon, Missouri
    Try these /forums/images/graemlins/shocked.gif:
    Diesel /forums/images/graemlins/burb.gif
  8. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    Chris
  9. georgiared84
    georgiared84 1/2 ton status
    Sep 5, 2002
    487
    Austell, Georgia
    Dang, That's a lot of heat! The only times I've seen them do that was with no oil. I cracked a case on a 10 bolt before and lost the fluid. I knew it was making noise but figured it was the bearing. Thought I'd keep driving to work and take it apart over the weekend. Melted and rounded off just like that. The bearings wore out and allowed too much sideways movement on the carrier which left it slipping on the pinion. Found the crack after it locked up on the road.
  10. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Yep, looks like it was run without oil and melted down. Gnarly! </font> /forums/images/graemlins/eek.gif
  11. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    well, ill post pics in a couple of days of the 10 bolt gov loc that i grenaded wednesday night about 50 miles from home
  12. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    My th-350's cracked case on the bell housing.. repair link at the bottom...
    How I fixed it: Ultra Bell Writeup
  13. Polaris
    Polaris 1/2 ton status
    May 30, 2002
    1,182
    Rhinelander, Wisconsin
    Well, it isn't as bad as some of you guys have but here is mine:
    One real good yank trying to pull a Bronco out of a mud hole.
    Total damage
    -bent transfer case mainshaft
    -broken tailshaft housing
    -dented muffler
    -busted driveshaft
  14. Txstruck
    Txstruck Registered Member
    May 25, 2002
    87
    Seagoville, Texas
    Chris
    Looks to me more like someone had welded the spider gears. They are evenly spaced it seems. /forums/images/graemlins/truck.gif
  15. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    nice breakage everyone.i wish i had taken pics of all the stuff ive broke and repaired.last week i busted the whole front hub assybly off at the outside bearing.still dont know how that happened.just driving down the road.
  16. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Future axle shopping tip: ALWAYS take the cover off and inspect the internals before you buy an axle assembly. Those booger welds on the ring gear would have a sure sign that you needed to keep on shopping. If the owner won't let you take the cover off for inspection, then move along and find another place to buy. /forums/images/graemlins/deal.gif
  17. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Oh yeah... It'll be cheaper to swap in another whole 14-bolt than to fix that one. /forums/images/graemlins/shocked.gif Just gears and bearings can set you back around $350. /forums/images/graemlins/frown.gif
  18. georgiared84
    Sep 5, 2002
    487
    Austell, Georgia
    But the ring gear doesn't even touch the spider gears, It wouldn't have even mattered if they were welded It wouldn't have changed the way the ring gear melted. Mine melted almost in the same pattern on the 10 bolt.
  19. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    surprisingly the bearings are perfect! races are fine, everything except the r&amp;p, which i found a good deal on ebay, for some temporary gears. spriders are all fine, everything is fine except the ring and pinion. i just finished cleaning my side gears, spiders gears, races, and carrier case, so i know! around here 14FF go for upwards of $400. i'm good to go now!
    where can i buy the axle shaft bolts, that bolt it to the drum? (hub bolts?)
  20. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    [image]http://www.geocities.com/big83chevy4x4/trannypic.html[/image]
    You can see the rest of the pics here
